diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Ta7250 - Click HERE for Original Thread
Christian
or TA7250BP which is the correct product name ;) I have a couple of chips of.
Does anyone know where to find a usable circuit involving these, or even a pinout diagram?
Here's a link to toshibas 1 channel audio-chips ( I suspect they are one channel since I found them in a car radio-unit) but I can't find it there.
http://www.toshiba.com/taec/cgi-bin...CategoryID=6983
/Chris
Txu
http://wwww.ges.cz/sheet/t/
great variety of TDAs
more pdfs index in
sangram
Send me your email id.
I've got the datasheet in pdf - 331 KB, too large to post.
In brief it's a 30-watt BTL car amp chip. The correct name is TA7250 BP.
30 watts into 2 ohms at 10% THD. Or 4 watts into 4 ohms at 0.015% THD.
Lots of protection circuitry. IC runs happier when run hot - 18 volts or so, usable for 2 ohms upto 10 watts, beyond that There's too much fuzz. Actually one of the best specs among the BTL ICs I've seen...
sangram
try downloading off this ftp site:
ftp://garlic.netsource.ch
Login: zanco
Password: dial
Look around for datasheets: alphabetically ordered, look under 'T' datasheets, there are two files. download the one which says "ta7250" not the one that says "ta7250BP"...
Page generated in 0.019092082977295 seconds with 17 queries,
spending 0.00575137 doing MySQL queries and 0.01334071 doing PHP things.
Copyright ©1999-2009 diyAudio.com
