diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
PCB for Component to RGB converter - Click HERE for Original Thread
SlaitH
I've got the schematics for a converter, but it's quite the ordeal to make into a PCB.
So i'll just ask you guys stright out if anybody has made a PCB???
Otherwise i'll have to do it the little more difficult way. ;)
I use Eagle to make the boards, if you got a better idea you're welcome to suggest.
Patrik
ringram
I've been trying to convert component to RGB as well and have come across several 'partial' designs. I have made a PCB, but if you're only making one unit, you're probably best just to use a wire wrap board and build it up.
I would appreciate it if you would share your schematic so that I can compare it what I have and see if I'm on the right track.
SlaitH
Check this site out instead there is a guy there who is much more able than I am:
Avsforum
//Patrik
Page generated in 0.038821935653687 seconds with 19 queries,
spending 0.02738357 doing MySQL queries and 0.01143837 doing PHP things.
Copyright ©1999-2009 diyAudio.com
