diyAudio.com diyAudio Forums Archive > Top > Source > Digital
How to use the Rotary Encoder to control the cs3310 ? - Click HERE for Original Thread
cac liu
I want to use the Rotary Encoder to control the cs3310,but I don't known how to use the Rotary Encoder,Could anyone help me?
janneman
You would need to use a microcontroller to decode the rotary control pulses and to write to the CS3310 registers. Have you ever done anything with microcontrollers?
Jan Didden
cac liu
I just know about the 89s51(mcs51)
I want to use to 89s51 to connect Rotary Encoder
analog_sa
Use it if you want. Probably an overkill but will certainly do the job.
cac liu
but how to write the program???
janneman
You only need two input lines. Here's a bit of documentation from a project I did once:
;--------System design notes-------------------------------------
; The encoders output a 2-bit value:
; the A-bit signals rotation,
; the B-bit signals the direction of rotation.
; encoder movement is detected by polling and debouncing in the b-port.
;CW channel A ___ ___ ___ [channel A leads channel B]
; ___| |___| |___|
; channel B ___ ___ ___
; |___| |___| |___|
; CCW: channel A ___ ___ ___ [channel A trails channel B]
; ___| |___| |___|
; __| |___| |___|
; A-bit B-bit Direction
; 0>1 0 CW
; 1 CCW
; 1>0 0 CCW
; 1 CW
You poll the A-bit (or hang it on an interrupt line) and then check the B-bit for direction of rotation. Ther's probably a ton of other ways to do this, this happened to work for me.
Edit: I realize the formatting is screwed up, if needed I can email it to you.
Jan Didden
cac liu
I had try to write some,but it has dithering,so it is not steady
Could you send me the program you had write for MCS51 , I want
to have a reference.
my mail box is cacworld@126.com
janneman
You have to debounce the bits. At the moment the switches close/open they bang around some time, depending on the quality of the encoder, but they all do it. So once you detect bit change, you wait a couple of milliseconds (I forgot exactly how many, it's trial and error and depends as I said on the type/brand of encoder), then after the delay you check the bit values and do your processing.
Edit: I think I used 6 msec debounce. Can't take too long, else you miss some pulses if someone turns it real fast...
Jan Didden
cac liu
I think I start to understand what you have just say.
I get to try again !
Could you send me your program to me to be referance?
Thank you very much !!!
janneman
I'm sorry but there is no 'program' to speak of...
It depends on the microcontroller you use, in 'meta-speak', you can do (with polling):
- see if the A bit is different from last time you looked;
- if yes, wait the debounce period;
- test the A-bit status (one or zero);
- test the B-bit status;
-depending on one of the four combinations, go to a routine to do whatever you want to do as action to the encoder movement.
I did this in a PIC and it is just a bunch of bittest and goto statements, but embedded in the program so I can't really send it to you.
But if you understand the process it should be a no-brainer.
Jan Didden
cac liu
How about this?
MAIN: MOV P2,#0FFH
S0: JB P3.6,S0
S1: JB P3.7,S1
JB P3.6,S2
JNB P3.6,S3
JMP MAIN
INC1: CLR P2.7
JMP MAIN
DEC1: CLR P2.1
JMP MAIN
S2: JNB P3.7,INC1
RET
S3: JB P3.7,DEC1
RET
END
janneman
Sorry, I can't decode this, I am totally unfamiliar with anything MC51...
Jan Didden
Page generated in 0.032887935638428 seconds with 17 queries,
spending 0.00725341 doing MySQL queries and 0.02563453 doing PHP things.
Copyright ©1999-2009 diyAudio.com
