diyAudio.com diyAudio Forums Archive > Top > The Moving Image > DIY Projectors
NView Media Pro question? - Click HERE for Original Thread
salzy
Does anyone happen to know if there is some kind of trick to getting the NView Spectra Media Pro to detect a VGA connection? I have tried plugging the cable from my computer to the panel and from my lap top to my panel and finally from a VGA Theatre (TV-3000) converter to the panel and it continues to say the same thing - no source detected. The panel works fine with S-video and RCA, but I spent a hundred bucks on the VGA converter so I'd like to see it in action! :) Any help would be much appreciated!
bsalzy@cogeco.ca Thanks!
iberia
Hi Salzy, I'm from Montreal and I have the same setup as you. I'm using an Nview Media pro with TV3000. I had the same problem as you. I was mad when I bought the TV3000 and it did not work with the VGA "digital" input of the LCD panel.
The Nview media pro was used on MAC computers. You cannot use the VGA 9pin "digital" input, you must use the 15pin "Analog" input. You HAVE to buy a 15pin(wide)->15pin(vga) converter. It was expensive because you can only find them in a "BMAC" store. Your setup with the TV3000 should work with it.
I attached a picture of it. Hope it helps!
regards iberia
iberia
I don't know why but it says that the picture is too large!!??
I will email it to you.
Page generated in 0.019644021987915 seconds with 17 queries,
spending 0.00638819 doing MySQL queries and 0.01325583 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
