diyAudio.com diyAudio Forums Archive > Top > Source > Digital
Where can I find Redbook on web? - Click HERE for Original Thread
Circlotron
Or do I have to buy it for some outrageous price somewhere?
halojoy
"CD Audio" is the usual name for what Red Book describes.
It is an agreement first made by Philips & SONY.
I have made a search.
Keywords: Standard definition "for download" "Red Book" "CD Audio"
This got it downto 19 hits with google
google hits - 19 hits
found these 2 PDFs:
SONY - CD Audio Manual 50 pages
Compact Discs - Technical Specifications 55 pages
;) Hope it helps, Circlotron
:cool: Will you start burning CDs?
/halo - just an end-user of CDs - so far
seangoesbonk
quote:
Whew! I thought he was looking for this ;)
peranders
quote:
Is there something special you are wondering about? Maybe I or someone else can give you some input.
You are searching for the CD standard "Red book" I suppose?
UrSv
Trusted Network Interpretation of the TCSEC (TNI), 31 July 1987. (Red Book)
http://www.radium.ncsc.mil/tpep/lib...CSC-TG-005.html
Circlotron
I was wanting to see if there was some way to squeeze 24 bit audio data onto a normal CD-DA track for the sake of playing it on a 24 bit DVD player. I did some looking in the meantime and it looks a bit scary... :cannotbe:
halojoy
That shouldn't be a probelem.
What I know the format uses 32 bits to store the musicinfo.
Even when music is recorded in 16 or 20-bits.
So there are a lot of unused bits.
You could say that CD-format is "future-safe".
No need to squeeze.
You might get some bits info from the datasheets of
these ICs that has to be able to handle ALL FORMATS:
CS8404 96kHz Digital audio Transmitter
CS8414 96kHz Digital audio Receiver
CS8420 24bit Digital audio Sample Rate Converter
Cirrus Logic CS8420
/halo - is dreaming of 32 bits Audio Sound in 384k/s sampling
- must be something! :o :eek: :eek:
Cirrus Logic CS8420
halojoy
this IC that has to be able to handle ALL FORMATS:
CS8420 Digital Audio Sample Rate Converter - Cirrus Logic homepage
on same page is a PDF:
AN022 Overview of Digital Audio Interface Data Structures (pdf) 02/1998, AN22REV2
and some other PDF you can get from this site
They are really specialist in CD-data - CIRRUS LOGIC!!!!!!!!
- must be something! :eek: :o :eek:
Circlotron
I looked at that one, is SPDIF type stuff unfortunately. CD technical spec thing and Sony thing are both specifications that CD manufacturers require of people submitting a recording to them for manufacture as discs. Thanks anyway halo. :)
AudioFreak
No need to squeeze.
[/URL]
No,
Redbook Audio CD's are encoded as 16bit 44.1kHz the remaining area on the CD is used for error correction etc.
The problem still remains, since no formal format exists for 24bit audio on a CD, unless you find some oddball non-standard player, you wont be able to play the discs even if you can find a way to create them. However, all is not lost, HDCD is a possibility (though it's only 20bit), DTS is a possibility, WAV (the file format that is) is a possibility.
Gunderz
What about rainbow book or the specifications for DVD-A and SACD, where to find them?
AudioFreak
quote:
Originally posted by Gunderz
....or the specifications for DVD-A and SACD, where to find them?
They are DVD formats so unless you have a DVD burner, they probably wont be much use to you.
bobhere
Red book costs big bucks!
There ia an equivalent standard that is available on the web ECMA-130 available at http://www.ecma.ch/publications/standards/ECMA-130.htm
There are a number of other standards available at the site, it is worth looking through the site.
The standard is everything a standard normally is, ie, presciptive rather than descriptive.
There is no real unused available space in the standard CD format.
Bob
Page generated in 0.042862892150879 seconds with 17 queries,
spending 0.00689030 doing MySQL queries and 0.03597260 doing PHP things.
Copyright ©1999-2009 diyAudio.com
