diyAudio.com diyAudio Forums Archive > Top > Source > Digital
silicon vs. quartz oscillators - Click HERE for Original Thread
soundcheck
Hi folks.
I stepped over this:
http://www.sitime.com/news/articles/NASA_Report.pdf
refereing to silicon oscillators as much more reliable than
quartz oscillators.
I never heard anybody discussing silicon oscillators as an alternative solution around here.
Perhaps somebody of the "clocking" specialists around
here could shed some light on the subject.
THX
Cheers
rossl
I looked at the data sheet for the SiT1 series. They specify 20pS RMS jitter.
There are small, inexpensive crystal oscillators available with low jitter.
Crystec 0.5pS and CTX 1pS. Crystec at Mouser and CTX at Digikey.
The jitter spec is more important to audiophiles than the spec for wide temperature range or the size reduction.
Most of us probably don't need a level of reliability that is necessary for NASA and satellites.
:D
oshifis
While we are at this, what are the usual jitter specs for a TCXO? I have a fairly large (about 2" x 2") Motorola TCXO with an internal 4 MHz crystal, a Colpitts oscillator and a 2-stage 74HC74 binary divider to 1 MHz. I replaced the crystal to 16.9344 MHz, and now it is serving in my Marantz CD-74. Is there a simple home method to measure/estimate/compare jitter values of different oscillators?
Page generated in 0.017574071884155 seconds with 17 queries,
spending 0.00601411 doing MySQL queries and 0.01155996 doing PHP things.
Copyright ©1999-2009 diyAudio.com
