| -_nando-_ |
Hello !!
I can imagine that everyone here that uses Eagle Layout Editor, must create a library that doesn't exists on eagle or that we can't find on the internet. Well...
So I want to propose to the users, to share the libraries, then everyone's life will be easier. We also can make a big ZIP package with all DIY Audio shared libraries and send to Cadsoft, then other eagle users will be able to download it.
What you think?
For example, I couldn't find 12AX7 tube on eagle, a very common tube. I need it's tube socket on board layout. Anyone here have it?
This can turn into a BIG topic, and will be much helpful for everyone here.
Let's share?
Best Regards!
:cheers: |
| ashok |
All this has been covered earlier I think. I can't tell you the posts right now , but do a search and you will find them. Eagle libraries by members especially for tubes.
Cheers. |
| -_nando-_ |
Yes, I searched and I found the tube library that I was needing. But my idea is create a big post with all libraries, and it will be like a database for the users, with all libraries in one topic.
Here is the Valve library ;) |
