| Slanski62 |
A few of the drivers I'd like to try (Usher and Dayton) offer frequency and impedence data as a .txt file, rather than a plot. Instead of using a tool like SPLTrace to import the data, will any of the FRD tools import the data in text format? Any help is appreciated.
Steve |
| EdwardWest |
The .FRD file type is a standard ASCII text file. It just needs to have the proper header and column delimiter. See this webpage for the specifics:
http://www.pvconsultants.com/audio/frdis.htm
You can use a standard text editor (MS Wordpad) to make the necessary changes, save the file and rename it to (whatever).FRD and it should load with no problems.
Hope this helps,
Edward |
| Slanski62 |
Edward, thanks a million for your reply. I'm just learning, so this helps my out a lot.
Steve |
