diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Loudspeakers
different driver units fo a wilson project - Click HERE for Original Thread
paul.42
hello everyone,i won't to know if anyone has any idea on differnt speaker units i could use in a wilson watt puppy clone project..all help would be gratefull.:)
BHTX
http://www.diyaudio.com/forums/show...p?threadid=9029
http://www.diyaudio.com/forums/show...?threadid=32552
http://www.deadwaxcafe.com/vzone/david/david.htm
http://highend.projektas.lt/?speakers/3
http://highend.projektas.lt/?speakers/4
http://www.geocities.com/bigmacx44/
http://www.geocities.com/razavihoma/
paul.42
thanks for those threads,had seen 3 of those,was thinking of going for scan speak 18w/8545 and waiting on email from audio technology about some of there 8152 20 08's.does anybody know the prices of these??should i be sitting down..now the tweeters,i'm not sure on..should i also go the scan speak route??
ShinOBIWAN
quote:
They're just over £300 each for the Flexunit. You get a discount of 15% for quantities over 2. I ordered four earlier this year and it came to £1120 including Danish VAT(25% BTW), shipping and the 15% discount.
paul.42
quote:
wow,on second thoughts,maybe not them then,can you point me in another direction..i should of said that my budget is around the £1000 mark,excluding the cabinets..
ShinOBIWAN
Yep, not the best value for money out there but good drivers non-the-less.
The Dynaudio drivers are going to be tough to come by now, you could get lucky though. That leaves the Scanspeak's. If your wanting to do a documented clone then always stick with the drivers used by the designer.
Ap
Keep in mind the Watt/Puppy is now up to version 8 and there have been a few changes along the way (notably different woofers & a larger bass cabinet).
My picks are:
midbass would have to be the Scanspeak 18w/8545,
tweeter Focal - check E-speakers for the TC120,
http://estore.websitepros.com/17367...?category=FOCAL
As for the woofers thats probably the hardest choice.
Hi-Vi D8.8 might be worth a look at, looks like they have made a rubber/plastic surround version.
http://www.madisound.com/catalog/pr...roducts_id=8202
or Peerless 830868 which are probably better value.
http://www.madisound.com/catalog/pr...roducts_id=1610
As for the cabinet/crossover thats another story!
Andrew.
Taco
You can also consider AudioTechnology 23I (cheaper than Flex). But still expensive.
The new Wilson Puppy/ Sophia use Scanspeak Alu cone's as woofer. I think it's this one with a different dustcap
http://www.tymphany.com/datasheet/printview.php?id=100 And the Revelator 18W/8531 as mid.
el`Ol
quote:
Are Focal drivers available for DIYers again:confused:
paul.42
My picks are:
Andrew.
thanks andrew for these address's,have just emailed them for the shipping costs
Ap
Also just remembered Morel could be another option for the woofer, either Madisound or Parts Express (on special at the moment!) has them, you may even find them locally as the company is based in Israel.
The Hu9.1 is designed for ported boxes & Morel use technology similar to Dynaudio.
http://www.partsexpress.com/pe/psho...FTOKEN=90037937
worth a look.
Andrew.
Page generated in 0.037590980529785 seconds with 17 queries,
spending 0.00481415 doing MySQL queries and 0.03277683 doing PHP things.
Copyright ©1999-2009 diyAudio.com
