diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
PP amp using 6p15P - Click HERE for Original Thread
pwan
My friend having 6P15P, 6N1P, 12AX6 & transf 250-0-250 - 250ma) around. Could you advise the good PP schematic that make use of these parts?
Thanks!
Eli Duttman
6p15p = SV83 = EL84N. The thing to watch out for is the fragile screen grid.
Follow the general pattern of the Dyna ST35. 12AX7 voltage gain block DC coupled to 6n1p "concertina" phase splitter. Both small signal tubes would be shared between the 2 channels.
SS rectify the B+. A separate filament winding, with a CT, for the 6n1p is a good idea. The CT is used to bias the heater off B+, which ensures the heater to cathode potential limit is not exceeded..
Are there any filament windings on the 250-0-250 power trafo?
Page generated in 0.02613091468811 seconds with 17 queries,
spending 0.01668382 doing MySQL queries and 0.00944710 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
