| dmk |
Hi all,
Long time lurker, this is my first post.:)
I want to build the Aikido pre-amp, and am looking at using a
Hammond 369AX TX and 6sn7 tubes.
The TX specs for Heater are 6.3v @ 2A, I found specs for 6sn7 putting Heater Current at .6A.
Will it be ok to run the four tubes (AC) off this supply? I realise the
combined amps will be 2.4 but hoping maybe this TX will be ok to
supply the current ?
I would prefer not to have to use a second TX.
Do you think I can get away with this setup ?? :confused:
Cheers
Dave |
| 2KW |
| I wouldn't do it. If it doesnt load up the transformer to the point that you don't get the full 6.3 initially, you may have long term problems with heat, and reliability. |
| minhaj |
Dave,
I am with paul. For long term use it might not be healthy.
Should you still want to try pls ensure heater voltage does not fall below 6 volt per tube and the TX does not get very hot after 2/3 hrs cont. use.
Regards |
| burnedfingers |
| I tried it a while back just because I had the transformer sitting on my shelf. The result was a transformer that ran very warm. I ended up replacing it with one that had a larger 6.3 supply and problem solved. |
| dmk |
Hi
Thanks for the replies, I will get another TX for the Heater Supply!!
Cheers
Dave |
| Colt45 |
| I'd try it first. Might be ok, depends how over/underrated the trafo is. |
