diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Car Audio
BC517 replacement - Click HERE for Original Thread
msm677
Any replacement for BC517 (silicon planar epitaxial darlington transistor complimentary to BC516)? I cant find any store here in philippines that has this.
please help me. thanks.
acid_k2
Try this one: MPSW45
Datasheet: http://www.onsemi.com/pub/Collateral/MPSW45-D.PDF
It's difficult to find an equivalent transistor, BC517 has a very high Hfe... :(
msm677
if i'm going to replace BC517 with MPSW45, should i replace all the other BC517 in my amplifier? I think I have 4 or more of them
msm677
between MPSW45-D and 2N6426, what will I choose to replace BC517? or are there any suggestion(s)? please help me.
thanks.
acid_k2
I think MPSW45A and 2N6426 are similar to BC517, both are good.
If you are repairing an amplifier, you have to replace necessarily all BROKEN components!!! :D
If you have to build a new amplifier, replace all BC517 with an equivalent one (MPSW45A or 2N6426)
:att'n: Attention: pin configuration of MPSW45A and 2N6426 is different from BC517!
msm677
I'm repairing my old earthquake pa-4050c amplifier? I tried finding these 2 transistors and none here sells this kind. any suggestion or replacement for BC517? please help.
acid_k2
-1- try finding them in internet shop of your country or near your country...
-2- look at the attached picture:
a darlington transistor is 2 transistor "in series" to obtain an high gain, so you can try that:
-find 2 normal NPN transistor, 1A, 40V,
-connect the pins like the schematic in the picture,
-you have a typical darlington transistor...
:bigeyes:
Good luck;)
msm677
:bigeyes:
Good luck;)
thanks, i'll try it.
Page generated in 0.040163040161133 seconds with 17 queries,
spending 0.01641917 doing MySQL queries and 0.02374387 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
