diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
grid chokes - Click HERE for Original Thread
Sjef
Has anyone any experience with the use of grid chokes instead of grid resistors in a 300B amp ?
I was wondering what the sonic benefits are.
Ryder
I did one with the well known Opera Billie 300b.
http://groups.yahoo.com/group/docto...M500%206S45.gif
very worthwhile
I imagine mileage will vary w/ circuit, no?
I Don't have any other experience with grid chokes.
I'd go for it.
Craig Ryder
Sch3mat1c
I see no advantage to it unless you're drawing grid current and want to keep the DC level exactly where you want it, but to each his own I guess...
Tim
Joel
Tim, there are actually some benefits to using a grid choke. All tubes have a fractional amount of leakage current in the "grid circuit". The big old triodes have a bit more, and so you'll often see a limitation on grid DCR - and you'll see two numbers, one for self bias, and one for fixed - the value for fixed being a fifth lower usually. This is because in the self bias situation the tube can compensate for any change in it's grid-cathode voltage relationship, whereas in the fixed situation - it can't.
You might ask, what's the big deal? Well, even a small leakage across 1 meg can shift the bias enough to cause problems.
So.... we can use a choke between the grid and ground instead, and those teeny tiny currents will only see a few thousand ohms, instead of 500k, etc. Of course the AC signal sees the inductance of the choke as a high resistance, and away we go!
Make sense?
A Hammond 156C is a cheap $10 way to try them out for yourself.:nod:
Sch3mat1c
500k? Bah. Go look at my Rock Your World thread. (And they spec 50k maximum...harrumph :P )
Tim
Joel
quote:
A 22k Rg seems like a waste of perfectly good signal voltage to me.
That amp is a perfect candidate for some grid chokes then Tim.:rolleyes:
Sch3mat1c
I still maintain that some wimpy 12AT7 pushing 150W of output doesn't feel right :)
Tim
Joel
What are you referring to?
Sch3mat1c
That theoretically I could use one but I didn't...
Tim
fdegrove
Well done Joel.You're spot on.:nod:
Cheers,;)
Page generated in 0.047713041305542 seconds with 17 queries,
spending 0.02433372 doing MySQL queries and 0.02337933 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
