diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
Oh yeah, 7KY6 - Click HERE for Original Thread
Sch3mat1c
Someone get out a 7KY6. Try it in pentode or triode.
:devilr: :nod: :devilr: :nod: :devilr:
(Don't worry about the oddball heater, it's within tolerance of 6.3V and most 6.3V will be running high (7V) anyway.)
Tim
fdegrove
Hmmm...interesting specs.
Cheers,;)
Sch3mat1c
Ha!
Coming full circle four years later, I have jammed together some crummy triode curves.
They look better in person.
http://webpages.charter.net/dawill/Images/7KY6.gif
Tim
dsavitsk
Very cool -- mu~30 and rp ~ 1K ... is that right? Pins are only slightly different from a 6688 or 7788, and it looks like a nice cheap lower mu alternative to those.
I've been looking for something to build a push-pull amp out of with some 5K:8 transformers, and didn't want to use the 2A3's I'm supposed to. These look to fit the bill quite nicely.
pmillett
This appears to be the same as an 11HM7 with a different heater. It makes a good driver tube for sure, especially in pentode mode.
Have you looked at the screen dissipation when in triode mode? A lot of the high Gm video pentodes when triode connected quickly exceed the G2 power ratings... G2 is usually the limiting factor (not the plate dissipation).
Also, as a triode, the miller capacitance is probably pretty high.
Pete
(some related pentode data: http://www.pmillett.com/pentodes.htm)
Page generated in 0.047038078308105 seconds with 17 queries,
spending 0.02872515 doing MySQL queries and 0.01831293 doing PHP things.
Copyright ©1999-2009 diyAudio.com
