| poynton |
| quote: | Originally posted by Katapum
Any ideas? :sad: |
You should initially at least follow the 'standard' upgrade path.
Remove the output muting and any headphone amp.
replace caps with Black Gate , Silmic, Cerafine or Oscon as appropriate.
Separate the power lines and add extra regulators plus more transformers if possible.
Add new clock.
Search the threads - there are many ideas around.
It is possible to replace the TDA1541 with the "A" but some circuit changes will be required.
Andy |
