diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Everything Else
Electric Fence - Click HERE for Original Thread
DavidWardlaw
I would like to build an electric fence around my garden so that animals do not enter it and eat all my vegatables. It's a very small garden (10' x 15') and every year animals enter it, especially at night and eat around half the vegatables (can't blame them, they are tasty). I have some experience in electronics and I have lots of parts laying around (batteries, wire, inductors, etc.). Does anyone know how I should go about doing this?
I_Forgot
Do you want to fry them or just discourage them?
I_F
DavidWardlaw
No, I do not want to fry them because I wouldn't want to deal with their dead bodies, just enough shock to shake them up a bit and discourage them from entering.
theAnonymous1
If your DIY venture doesn't work out; I have a real electric fence box you can have.
I've had the thing for years and don't even remember where it came from. Pay for shipping and it's yours. I'll post a pic of it in a bit, my camera battery needs recharged.
EDIT: OK, here is a pic of it lighting up a neon tube so you can see that it works. Picture is blurry because it was hard to take the pic right as it lit up (intermittent output).
Cal Weldon
Do you have troubles with slugs or snails? I have a solution.
john blackburn
Whats the slugs and snails info? We are having a plague of the things in England, what plants haven't drowned are sorely nibbled.
star882
quote:
A normal fence zapper is way overkill for those. I remembered one time when I zapped a snail with a 9v battery.
I have also heard that just copper works since when it's in contact with the snail, it forms a battery that gives a small zap without an external power supply.
es44
Actually there are people having constructed electrical fences for snails. It seems they are using either 12v dc or 12v ac, supposed to be enough to fry them.
We are invaded in Denmark by some Sibirian snails, who eat our own natural snail. They are real cannibals, and a very big plague, as they also love our vegetables.
Sorry the links are for Danish sites, but maybe you can "read" the pictures.
Best regards Ebbe
http://www.kirstinsbregner.dk/regis...gle/snegle.html
http://www.dbamott.dk/snegle/elektrisk_sneglehegn.htm
Nutzy
I once made an electric fence to keep the dogs out of the veggie garden. They were both very keen on tomatoes and strawberries!
I got a couple of high voltage - low value caps, a rectifier, a diac, a triac, a charge limiting resistor, and an old ignition coil.
As the rectifier is fed through the charge limiting resistor, the caps get charged up. As the voltage of the caps hits the break-over point of the diac (set up with resistors, or a POT) it triggers the triac on which discharges the caps through the ignition coil primary.
It produced a nasty sting that would make the dogs yelp when they got up enough nerve to touch the wire every few weeks, but not enough to cause my idiot friends much drama when they would hold onto the fence wire in their game of dare!:whazzat:
Caveat - This method is not entirely...errr, isolated from the mains!:hot:
TwoSpoons
I used to design these things for a company called Stafix, now owned by Tru-Test. The easiest thing would be to go to a farm store and buy a "Strip Grazer". This is a little unit usually used to power about 20-50 m of portable fence, and used by farmers for "break-feeding" or "strip-grazing" of livestock. They put out about 0.1 joules at around 7-8kV. They are safe, robust, and painful.
Should you really, really want to build your own, a 20uF charged to 100V (thats about 0.1 joule), dumped into the primary of a car ignition coil every 1.5 seconds with a thyristor should do the job. You will need anti parallel diodes across both thyristor and storage cap. I'll leave timing and charging up to you. Be sure to have lots of isolation (30kV is standard) if you power the thing from mains!
Don't go faster or more energy - 1: you don't need it, and 2: you'd be heading into dangerous territory
Me - I'd just go buy one, along with the plastic insulators you'll need for the fence.
(personal claim to fame: designing the worlds most powerful fence energiser with a whopping 38J output at 10kV. Nearly killed myself when I got across the internal storage caps (900V dc:120uF IIRC) Nasty.)
DavidWardlaw
No, I have no snail problems whatsoever. I rarely even see a snail around anymore...mostly squirrels, and racoons etc...They like my tomatoes, cucumbers and cabbage...I understand most of what you all have advised me except...what is a thyristor??? I never heard of it.
theAnonymous1
David, I'm not sure if you saw my earlier post, but if you want the electric fence box I have let me know. If not, it's going in the trash.
DavidWardlaw
ooh sure, no problem, how much is shipping?
jnb
As small animals would easily get around fence tape, would it work to electrify a mesh fence? Could it be run close enough to the ground so animals wouldn't burrow under it or would there need to be a cement base, and how would a fence go with frost?
DavidWardlaw
I tried electrifying a mesh fence, but there is just too much of it...the drop in voltage is way too great...by the way, when it gets to be so cold that there is frost on the ground, plants don't grow and animals don't go into gardens, so an electric fence is unnecessary...
Nutzy
I had three lines of polywire going around the garden. All up there would have been around 100ft of wire. The lowest of the wires was set so that the Jack Russells couldn't get under it, high enough so grass didn't become an issue.
I would suggest that electrifying mesh would lose way too much voltage leak to the air.
Something I always wanted to try instead of the coil approach to an electric fence was the Marx Generator. I was uncertain if this would have a low enough resistance to run the wires though. I thought that the DC voltage may be less leaky than the rapid rise AC ring the ignition coil outputs. <shrugs> Dunno....
I was stopped in traffic one foggy morning under a 330KV transmissions lines....the discharge noises coming off those lines was more than a little scary!
Pete
Page generated in 0.040910005569458 seconds with 17 queries,
spending 0.00859666 doing MySQL queries and 0.03231335 doing PHP things.
Copyright ©1999-2009 diyAudio.com
