diyAudio.com diyAudio Forums Archive > Top > Source > Digital
How can I fix my cd player Sony CDP-M26? - Click HERE for Original Thread
Katapum
Sometimes when I push close key cd tray close and open again. How can I fix it?
I’m also looking to a service manual.
Katapum
Nigel Goodwin
It's usually just the small drive belt slipping.
Katapum
quote:
I only see one belt in CDP and it seems ok but ….
Nigel Goodwin
If it's not the belt slipping then it's usually the limit switch.
Katapum
How can I find limit switch without service manual?
Nigel Goodwin
quote:
By the obvious switch that the mechanism hits! :D
Katapum
I´ll try to find it.
Thanks Nigel Goodwin.
Katapum
Katapum
Where can I find CXA1291P datasheets? What’s for CXA1291P chip?
Extreme_Boky
The IC appears to be dual operational amplifier, designed for "higher currents" probably around 100 to maybe 200mA to drive the motors. The Vcc and Vee are probably of larger area directly soldered to PCB tracks for cooling. You don’t really need data sheet to fault find - all the values you need are included in the service manual.
Good luck,
Boky
Katapum
:cool:
tricomp
Hi Katapum,
I just saw this post today.
I can send you the service-manual by e-mail if you give me your e-mail address.
...but Nigel Goodwin is right, it's the tray-in switch most likely that gives these problems.
Kind regards,
/tri-comp
Katapum
Hi tri-comp,
If you can send me service-manual I appreciate a lot (katapum2@hotmail.com).
The problem is: I cannot find tray-in switch. I opened cd player but I saw nothing. Have you a photo whit a tray-in switch.? :smash:
Best regards,
K
Katapum
quote:
Originally posted by tricomp
Hi Katapum,
Kind regards,
/tri-comp
Tri-comp :king: :worship:
gbiker
hi everyone,:)
I woule like to know What dac is it in sony cdp-m26 and also some impresions about how it sound.
Thanks in advantage :)
Katapum
quote:
Originally posted by gbiker
hi everyone,:)
cxd1161p
gbiker
Page generated in 0.034847021102905 seconds with 17 queries,
spending 0.00802159 doing MySQL queries and 0.02682543 doing PHP things.
Copyright ©1999-2009 diyAudio.com
