diyAudio.com diyAudio Forums Archive > Top > Source > Digital
DEQ2496 continual reboot(?) Help! - Click HERE for Original Thread
lcjohnson
I have a Behringer DEQ2496 that signal wise sits between an SRC2496 and a DCX2496. It has been used in a home stereo for about 2 years.
Starting about 6 months ago I got an intermittent signal cutout during the first 10 minutes of warmup of the DEQ2496.
Now when I turn it on, the front LEDs blink together every ~1/2 second. This is continuous, otherwise nothing else. Is this a cyclic reboot?
I took the cover off and poked around for shorts or burned components, exercised the connectors, etc., - to no effect.
Anybody out there had this problem? Any suggestions? Otherwise I'm looking at 300 clams for a new unit...
ampsarus
I had the same problem with mine when it arrived used via eBay. I removed the boards and put tape down on the bottom of the chassis and put everything back together. It was a stab in the dark, as this method of "repair" fixed a shorting issue I had with one of my DCX's a couple years ago.
So far so good, no rebooting since then. (knock on wood)
Good luck.
Page generated in 0.016602993011475 seconds with 16 queries,
spending 0.00722766 doing MySQL queries and 0.00937533 doing PHP things.
Copyright ©1999-2009 diyAudio.com
