diyAudio.com diyAudio Forums Archive > Top > Source > Digital
OPA1632 + PCM1804 question - Click HERE for Original Thread
dismirlian
Hello, I am designing an ADC input stage for the PCM1804, usign the OPA1632 differential opamp. Reading the opamp's datahseet, I found a recommended circuit for this implementation (see attachment). The question is: is it necessary to buffer the VCOM pin of the A/D, or can I connect it directly to the Vocm pin of the opamp (perhaps through an RC filter)? Thanks a lot.
Diego.
Keruskerfuerst
The datasheet of the PCM1804 does not mention the output impedance of the Vocm pin.
Advantage of the additional op: lower impedance of the Vocm source.
Disadvantage: maybe higher offset.
I would say: just try out both circuits.
dismirlian
Thanks for your answer. I noticed the lack of information regarding the output impedance of the Vocm pin, but the input impedance of the VCOM pin of the opamp is 34Meg, according to the datasheet.
I'll follow your suggestion and try both circuits.
Diego.
Page generated in 0.016638040542603 seconds with 16 queries,
spending 0.00710535 doing MySQL queries and 0.00953269 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
