diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Pass Labs
Mini-Aleph Heatsink size ??? - Click HERE for Original Thread
patoff
What is the minimum size for each mini-aleph xtor passif heatsink for 15V rail PSU?
Standard Socket 370 CPU Heatsinks without Cooling Fans, is it good?
P.s.: Sorry for my engish, I'm a French-speaking
vdi_nenna
That's probably too small. My mini-a's heat sinks are approx 150mm x 430mm x 50mm per channel at 1 amp per channel. It runs very warm.
A way to test if it is too hot- if you can hold your hand on the heat sink for a few seconds without discomfort it is ok. If you can't hold your hand on the heat sink at all, even for 2 seconds, it's too small a heat sink.
Hope this helps,
Vince
patoff
Thanks vdi_nenna
I try to find a bigger heatsink
ssmith
Not very scientific, but for ideas have a look at the gallery on the pass diy website:
http://www.passdiy.com/gallery-misc.htm
Page generated in 0.031004905700684 seconds with 17 queries,
spending 0.01806712 doing MySQL queries and 0.01293778 doing PHP things.
Copyright ©1999-2009 diyAudio.com
