| vickyz |
hi. im from malaysia.im selling genuine dls stuff.plz do have a look......
ULTIMATE SERIES UR6i RM2500
CLASSIC SERIES B6A RM550
IRIDIUM 6.3i RM3700
IRIDIUM 12" RM1900
ULTIMATE A6 RM3200
Number of channels 1
Amplifier class AB
Typical power in 4 ohm 500 W
Typical power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Typical power in 1 ohm 1200 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance > 10 kohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal 1
Dual DC inputs 1
Remote base level control 1
Remote phase shift control 1
Integrated fan 1
Power consumption (idle) 0,6 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
ULTIMATE A4 RM4700
Number of channels 4
Amplifier class AB
Typical power in 4 ohm 4 x 85 W
Typical power in 2 ohm 4 x 145 W
Typical power in 1 ohm 4 x 220 W
Mono bridge mode 4 ohm 2 x 250 W
Mono bridge mode 2 ohm 2 x 400 W
Frequency range 10 Hz - 50 kHz
Filters channel A & B LP: 50-125 Hz. HP: 20-200 Hz / 60-600 Hz
Filters channel C & D LP: 45-200 Hz / 90-400 Hz. HP: 20-200 Hz
Dual DC inputs 1
Power consumption (idle) 1,5 A
Power consumption (max) 95 A
Rec. power cable Minimum 4AWG / 21 mm2
Dimension (W x D x H) 465 x 240 x 73 mm (18,30 x 9,45 x 2,87 inch)
Weight 6,6 kg ( 14,55 lb)
ULTIMATE A3 RM3700
Specifications
Number of channels 2
Amplifier class AB
Typical power in 4 ohm 2 x 150 W
Typical power in 2 ohm 2 x 270 W
Typical power in 1 ohm 2 x 425 W
Mono bridge mode 4 ohm 550 W
Mono bridge mode 2 ohm 870 W
Mono bridge mode 1.33 ohm 1000 W
Input sensitivity 0,2 - 7 Volt
Input impedance > 10kohm
High pass filter 20 - 200 Hz
Low pass filter 50 - 125 Hz
Dual DC inputs 1
Power consumption (idle) 1,1 A
Fuses 4 x 30 A
ALL ABOVE ITEM COME WITH 1 YEAR WARRANTY UNDER NTC WORLD.
IF INTEREST IN OTHERS SERIES AND WANT TO KNOW THE PRICE,PLZ SMS ME THE MODEL
PLZ CALL UP IF INTEREST BUYER 016-2510646 |
| garage1217 |
Guys, mabey this guy is legit but I CAUTION you, there is a MASSIVE amount of copy cat DLS stuff coming from overseas. Trust me I know, I know the us rep and currently have a large amount of dls gear in my show car. I have seen the copies personally, they look darn good but pop the lids on the amps and they are garbage in a pretty shell.
Do a search and you will find all kinds of info about DLS fakes being passed off that are not even close to the real deal. Just a caution... |
