diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Tubes
calling Moray James, and others ..wav8 or 6BM8 schemtics--PP. - Click HERE for Original Thread
Nanook
looking for some PP 6BM8 schematics. (Dave it seems that what I thought were SE trannys are in fact PP).
As the wave 8's had received good press, I'd like to emulate them. I have the tubes, the sockets, a 5GR4 based power supply, a phono stage. just want to add a couple of pairs of RCA inputs, a good ground, and an attenuator.
Somewhere I thought Moray had modded sopme pairs of these. Moray are you out there?
planet10
I thot i had a Wave 8 map but can't find it.... it is a gain stage>concertina>ouyput stage topology. All of the following bit 1 are the same topology. Hopefully from the lot you'll find an agrreable set of passive parts...
dave
planet10
planet10
Nanook
Elsewhere I had asked if I need to bring anything to the Island. Anything?
planet10
quote:
I thot i'g covered that off... be a good idea to bring your sleeping bag & a pillow if you need it...if you have a roll up camping pad it wouldn't hurt either... otherwise whatever you want... you driving?
dave
planet10
planet10
Nanook
probably...think I'll bring my wife,a day or two early and "sight see". I may be able to break down Hemp8/OBs , and a t-amp intergrated. If I can get the tube amp done maybe that too...sorry no turntable.... hm,, the replinth travels well...
and for the schems..
planet10
the hemps would be cool... i also have a baffle here with replacable driver module so you could just bring the drivers
dave
planet10
planet10
moray james
Nanook: you will need to give ne a little time to dig the schematic up for the Wave 8 they are nice amps. Do you need output transformers? I have a set from a pair of Wave 8's. I had Joseph Lau build me a set of ultra linear transformers for one of the sets I owned (three pair in all). If you need output transformers send me a PM they are yours. Regards Moray James.
http://www.drtube.com/datasheets/6bm8svet1996.pdf
http://www.stevenfenner.com/Music/U...B_Schematic.jpg
http://www.tube-town.de/diy/sv-amp/svetlana-amp.html
http://www.lh-electric.4t.com/bin/6W.gif
http://perso.orange.fr/michel.terri...ilips-h4f74.htm
http://www.bonavolta.ch/hobby/en/audio/ecl82_2.htm
http://www.electra-print.com/el84psapp.php
http://www.diyaudio.com/forums/show...&threadid=57411
http://www.bonavolta.ch/hobby/en/audio/ecl82_3.htm
http://www.mixtel.pwp.blueyonder.co...o/smallamp.html
planet10
Nanook
I have some PP output trannys and the Powwer supply trannys as well. Was planning on a intergrated version of sorts. I am sure the trannys are all Hamond, even though I can't find anything on them (Sparton Radio of Canada reciever is the donor).
apparently a 12M6 amplifier of sorts (RCA under liocence to Sparton).
Thanks both, I gotta get some sleep:)
Nanook
I tried emailing moray james directly from his website , not sure if he got it.
moray please email me ... (or Dave if you have it as well). I'll be in town tomorrow and would like to drop by.
stew
Page generated in 0.038688898086548 seconds with 17 queries,
spending 0.00933599 doing MySQL queries and 0.02935290 doing PHP things.
