diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
FT: Spamps; Electrohome speaker lamps - Click HERE for Original Thread
MichaelPublic
Hi all,
I have a couple old Electrohome speakers, upwards firing with diffuser I suppose it's called, shaped like lamps. The images should make that clear-ish. These are weird enough that I figured someone here would want them. They work, but need rewiring. Apparently the Philips drivers are alright in full range projects.
I'd like to trade for a decent project box/enclosure like the aluminium Hammonds or similar, I'll be using it for a headphone SOHA amplifier.
Other cases considered. I'd like to keep shipping inside north america if possible. Email me with possible trades. If you're frantic for 'em and don't have a case to trade err, email me.
They have the Philips 7060/M8 full range speakers in them. Here's information courtesy of one of Planet10's sites.
<"6" (155mm) 8W AD7060/M8 Full Range / Whizzer Cone
Philips 6 1/8" (155mm) paper cone full range drivers with 2.5" (65mm) whizzer cone -- this is terminated with a flat ring which helps reduce whizzer resonances. 8 ohms (DCR=7.3 ohm). They have a textured paper cone extending into treated accordian surrounds, 1" (25mm) voice coil, and the trademark octaganol 8-legged stamped basket. they have a 3rd tag for grounding the basket.
Efficiency about ........91 dB ..">
They have an amusing surround type effect that is surprisingly effective, they need to be refurbished or I can just ship the drivers.
If I had a room with shag carpet I'd use them for retro funky surrounds.
Page generated in 0.019963979721069 seconds with 17 queries,
spending 0.00624061 doing MySQL queries and 0.01372337 doing PHP things.
Please support our sponsor.
