| auric |
Hi:
Does anyone have any dead CDM 44/33 cd transports with the servo controller board? I'm looking for some exotic parts on it.
Also is there a list of CD players that had the CDM 44/33 inside?
Can replacement CDM 44 still be found today?
Thanks,
Derek |
| auric |
Thanks Array!
Do you or anyone know the difference between
CDM 4/33 vs CDM 4/19?
Derek |
| Runco990 |
The difference between the 2 mechs is the motor. If you need a CDM-4/33, you can use the optical pickup from the /19. But the 33 has a hall brushless motor whereas the 19 uses a cheap dc motor. |
| auric |
Thanks for the reply.
Are the two mechanisms swappable? In otherwords, can I take plug a CDM 4/19 right into the controller designed for CDM 4/33?
Derek |
| Runco990 |
| Only the laser assembly.... NOT the motor. |
