diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
PA100 with DC SERVO? - Click HERE for Original Thread
YFW
I just check the application note of NS,AN-1192.
When building PA100-100W parallel circuit,is DC SERVO circuit is required?
And,is there anyone try to bridge the circuit BPA200 by using transformer?For example,the transformers from Jensen and Lundahl.
Ponz
PA100 use three parallel 0.5Ohm resistor to protect output DC voltage
problem. the function of these resistors is a "buffer". let two of LM3886's offset voltage not short directly.
But i think DC Servo is a better solution.
This circuit needs two DC-Servo, one DC-Servo for one LM3886, and
control each LM3886's output offset voltage to zero.
btw, the performance of DC-Servo is the key point! You needs a high impedance , low input offset and enough slew-rate OP if you want to made it with OP. OPA604, OPA134, or LM318 is a good choice.
Netlist
Ponz, you have mail. :)
/Hugo
YFW
How about the sound quality between the two solutions?
gootee
If you matched the gain-setting resistors very closely, you "could" leave out the DC Servo. But then you'd need DC blocking capacitors, which will probably not sound as good.
If you use the DC Servo, which is a good idea in my opinion, be aware that the design and implementation of the DC Servo are very important. DC Servos have gotten somewhat of a bad reputation, maybe because of the many poorly-designed ones that have appeared in commercial equipment, and maybe also because it's relatively easy to do them wrong, especially in DIY situations.
You want the DC Servo's integrator's F-3dB to be below 1 Hz. The servo's opamp needs to have high performance, but with very low offsets. The integrating capacitors should be high quality film types, with low Dielectric Absorption, such as those with dielectrics made of teflon, polystyrene, or polypropylene (in order by preference [and probably by cost, too]).
The "better" DC Servo designs have additional low-pass filtering, most-often after the integrator (but sometimes also before the integrator). Usually, the post-filter's F-3dB is set to be about 10x higher in frequency than the F-3dB of the integrator, to ensure stability. You could, for example, split (into two resistors) the resistor shown after the integrator output (in AN-1192) and put a capacitor to ground between the two resistors, to form a passive low-pass filter, there.
However, if you use a dual opamp for the integrator, you'll have a spare opamp. So why not use an active filter?
Here is one example of a DC Servo circuit that I have used:
http://www.fullnet.com/~tomg/DC_SERVO.jpg
For that circuit (which uses a simple 3rd-order active Sallen-Key "DC-accurate" low-pass post-filter): From the integrator input to the amplifier input, the response is 98dB down, from DC up to about .01 Hz. Then it rolls off to about 147dB down at 10 Hz. Then the roll-off steepens to bring it to about 276dB down at 1 kHz, and about 327dB down at 6 kHz. (NOTE that those figures assume that the servo's output resistor's value is 20X the value of the resistor at the amp input that forms a voltage divider with it.)
NOTE that if the amplifier output voltage can swing farther than the servo can handle (which might often be the case), then a voltage divider might need to be used on the servo's input.
Disclaimer: "Other parameters may need to be changed. Your mileage may vary. Use at your own risk."
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
Ponz
the schematic that gootee posted is a great circuit!
additionally, the other point of dc-servo is the leakage current caused by the capacitors in the dc-servo. so these capacitors must be quailfied .
gootee
Ponz,
Thanks, very much, for your positive opinion!
And I agree that the capacitors' specs, as well as the opamps' specs, should be very good and pretty-carefully considered, in order to get the very best performance.
I originally developed that circuit for use in my Curve Tracer product's power amplifier, to remove any remaining DC offset from the sweep signal that is applied to the device-under-test. (And by the way, that amplifier design has been powered by an LM1875T since around 1998 (or 1999; I forget), way before I even thought much about using them for audio.) For that application, I used the indicated polypropylene and polyester capacitors, and an Analog Devices OP275 dual opamp, with "good enough" results, since it wasn't really too critical (being, already, actually, "overkill", for that particular amplifier, which was already very precise and very tightly controlled in several other ways).
I just ran some LT-Spice simulations of the DC Servo circuit, again, with an amp model attached. Testing it with no signal, except for a DC offset, it lowers a 1-volt initial DC offset to 50 mV in about 2.25 seconds, and gets it down to 1 mV within about 4.72 seconds. With an initial 1-volt DC offset, the integrator output starts at only +2.5 volts and eventually goes to only -2.5 volts by the time the offset has been removed. So there may be a bit of an "overkill" component for this case and the speed and dynamic range for audio applications might be able to be optimized better (i.e. maybe slower speed and less range could be better, for this application).
With a 22V p-p 60 Hz sine signal included, I can see that the integrator's output (which then still has the same average levels and timing as the "no signal" case, of course) has about 391 mV p-p of the sine riding on it, and the post-filter's output has about 424 uV p-p of the sine, which would mean about 20 uV of the sine would be present at the amp's input pin, after the R/20R divider, whereas the total signal at that input measured 1 V p-p.
So the residual sine component after the filter, at the amp's input, is about 94 dB below the signal at the amp's input, at 60 Hz.
With a 1 kHz sine signal (1 V p-p @ amp input, 22V p-p @ amp output), the integrator's output has a sine component that is about 23mV p-p, while the post-filter's output has a 1 kHz sine component of about 610 nV p-p (or about 29 nV p-p at the amp's input, which is 150 dB below the signal level). And that just gets better, as the frequency is increased.
For a kind-of "worst case", I also ran it with a 20 Hz 22v p-p sine output. For that case, the integrator's output has about 1.2 v p-p of the sine and the post-filter's output has about 43 mV p-p of the 20 Hz sine, which would mean about 2 mV of the sine is at the amp's input pin, versus the 1 V p-p signal, which puts the sine fed back through the servo to the amp's input 54 dB below the signal, at 20 Hz.
In the Curve Tracer product, I only used this DC servo circuit for signals down to 60 Hz. And I also had a response-speed-related design-goal component, for that application. So maybe there's room for improvement, for use with audio and down to 20 Hz.
The post-filter's cutoff frequency can be varied by changing only the capacitor values, more-or-less in proportion to each other, i.e. using standard capacitor values. So perhaps the 0.47uF/0.47uF/2.2uF should be changed to 1uF/1uF/4.7uF, at least for the purists. But then the integrator's caps' or resistors' values would probably also need to be approximately doubled. Or, if that's too slow, maybe 0.68uF/0.68uF/3.3uF could be used for the filter and either the caps' or resistors' values for the integrator could be increased by about 1.5X.
There may also be a small residual DC offset that varies slightly with the configuration, that someone might want to trim out, although it's probably already <= 1 mV.
Sorry to "blather-on", for so long, about all of that. I love this kind of stuff.
- Tom Gootee
gootee
- Tom Gootee
CORRECTION:
The post-filter is NOT a "Sallen-Key" topology.
I stole that filter design directly from Figure 13 of the datasheet for the LTC1968, from http://www.linear.com , several years ago. They don't name the filter topology, there, except to call it "DC Accurate".
AndrewT pointed out in an email that it didn't look like the Sallen-Key topology, which prompted me to search for the datasheet I'd gotten it from. It turns out that they were only _comparing_ it to a Sallen-Key filter, and I somehow got confused about the names.
So, I still don't know the name of the filter's topology. Obviously, the first pole is just a passive RC lowpass section. It's the scond-order part, with the opamp, two capacitors, and two resistors that I'm referring to. To me, it seems to most-closely resemble the classic FDNR filter topology (Frequency-Dependent Negative Resistor). But's it's different from that, too. If anyone knows of a name for that type of filter, please let us know.
At any rate, I do recommend reading that section of the LTC1968 datasheet, if you're interested. You will see exactly why that particular filter topology is perfect for a DC Servo's post-filter.
I apologize for the error.
- Tom Gootee
glennb
...You want the DC Servo's integrator's F-3dB to be below 1 Hz. The servo's opamp needs to have high performance, but with very low offsets. The integrating capacitors should be high quality film types, with low Dielectric Absorption, such as those with dielectrics made of teflon, polystyrene, or polypropylene (in order by preference [and probably by cost, too]).
Agree.
quote:
Here is one example of a DC Servo circuit that I have used: http://www.fullnet.com/~tomg/DC_SERVO.jpg
Hi Tom, there is no point in talking >120 db figures, as the resistor noise will swamp any HF rolloff above a few Hz unless you keep the resistor values very very low.
peranders
DA is hardly a problem in a DC-servo. I have noticed it in a dual-slope ADC, there you had an offset which you could notice just by reading the display.
A DC servo doesn't have to be so complicated, a good opamp connected as in integrator.
Example here:
http://sjostromaudio.com/_unsql/hif...oads_qrp02.html
peranders
For that circuit (which uses a simple 3rd-order active Sallen-Key "DC-accurate" low-pass post-filter): -
How do you get -60 dB/oct from two caps? I can agree on a 2nd order filter, the left opamp UA2.
peranders
Enough slew rate is < 15 V /us, you don't need a fast opamp like LM318. OPA134, OPA227, NE5534(!) or slower is a good choice. The opamp should have decent audio properties up to 1 kHz which very many have. In my QRP02 Gainclone I have one half of AD8620, quite an overkill but it does a really good job though.
Ponz
I had tried to use NE5534 in the several DC-Servo circuit.
But NE5534 seems cause to much DC offset even sounds not bad.
peranders
If you do it with you'll get 4 mV or so. Not much! :no:
gootee
quote:
Hi peranders.
There are three caps, which makes a third-order filter.
The filter is fully described in the referenced datasheet (LTC1968, Figure 13, linear.com).
gootee
quote:
That's certainly true, Glenn. I was merely quoting the raw figures from the ideal simulation.
gootee
Hi, peranders.
It's really always just a question of how MUCH of a problem it is. The original application for my servo circuit needed well-under 1 mV of offset. And the WIMA 0.22uF polypropylenes are relatively cheap, anyway. So it's probably reasonable-enough to use them, even if it's just for audio.
quote:
[i]
Example here:
http://sjostromaudio.com/_unsql/hif...oads_qrp02.html [/B]
I agree that it doesn't HAVE to be so complicated. It just makes it better. When I first made the circuit and used it in the original application, there was a measurable increase in output THD under some conditions, without the additional filtering.
gootee
Yes, 15V/us is probably more than enough, for most chipamps at least. The slew-rate just needs to be greater than the slew rate of the main amplifier, by some factor (possibly as low as >= 1). However, faster might be better, too, up to some point.
And another very important specification for a servo's integrator opamp is low offset drift.
- Tom Gootee
gootee
Example here:
Hi, peranders.
In your qrp02r0schema_p2.pdf, what is "LM3386TF"? :-)
(I assume you meant to have "LM3886TF".)
- Tom Gootee
Ponz
- Tom Gootee
yeah, i agree your point, low offset drift in the intergrator is other important spec.
although some typical dc servo circuit will produce dc offset itslef(usually cause by lpf), low offset drift with OP amp is also important.
peranders
How much did the THD increase?
If you have 2 poles you'll get small thump and the closer the second pole is to integrator pole the more damped oscillations you'll get. Inserting even a third pole must increase the unstableness, yes?
gootee
Hi, peranders.
I'm sorry. I don't know. It was several years ago and I didn't make notes of that testing. It should be able to be seen with LT-Spice simulations. If I get time, I will try that again.
quote:
[i]If you have 2 poles you'll get small thump and the closer the second pole is to integrator pole the more damped oscillations you'll get. Inserting even a third pole must increase the unstableness, yes? [/B]
It would increase the _tendency_ toward instability. But it is not unstable, as I have shown it.
There is a small "thump" and then about 2 cycles of additional overshoot and ringing at the filter output. With the circuit as shown, there might also be up to a few hundred microvolts of very low frequency steady-state oscillations, at the amplifier output.
So maybe it is not as stable as it should be, for this application. But, as I mentioned, for audio applications, the circuit might be able to be improved by lowering the filter's cutoff frequency. (But, CONTRARY to what I said in that same previous post, the integrator's frequency should probably NOT be lowered by the same proportion.)
There are trade-offs to be made, of course, as always. A steeper filter is better at keeping phase-changed audio from feeding back into the amplifier input through the servo loop. But the servo loop must also not cause other problems that might be worse.
For others who might be reading this: It is very simple to simulate an amplifier with a servo loop, with LT-Spice (free from http://www.linear.com), or any other Spice software. By running AC Analysis and Transient Analysis, all of the preformance and stability issues can fairly-easily be assessed and adjusted.
I just now did such a transient LT-Spice simulation, using capacitor values for the three filter capacitors that were approx double the values shown in my original schematic, i.e. 4.7uF, 1uF, and 1uF instead of 2.2uF, 0.47uF, and 0.47uF. The integrator was not changed. With these new values, even all of the very small, very-low-frequency oscillations appear to ge gone.
With a 23mV DC offset in the amp's input signal (a 1 kHz 1 V P-P sine), which would give 22 V P-P out, and, if used without the servo, over 500 mV of DC offset, I see that, at turn-on, the output experiences a 7.2mV downward thump during the first 0.13 seconds, then about one cycle of approx 4Hz ringing (only about 200 uV 0-P). And then the output rises cleanly by 2.5 mV over 4 or 5 seconds, until the offset is within about 0.25 mV of zero. (Well, it also looks like there might be about 2 uV p-p of steady-state output oscillation at about 0.2 Hz or so. But that is insignificant.)
Maybe I should mention that, for my examples, I have been using a non-inverted main amplifier configuration, and have an inverting opamp buffer amplifier between the filter output and the "R1" shown in the servo schematic I posted. The main non-inverting amplifier is simulated with an opamp, and has 10K || 2.2pF from output to - input, and 499 Ohms from - input to ground. R1 in the servo schematic is 10K, for this simulation, connected to the - input of the main amplifier, and follows the inverting buffer amplifier that I mentioned, which is an opamp with 10K || 4.7 pF from out to - input, 10K between - input and filter's output, and 4.99K from + input to ground.
With that configuration, it's possible to measure the filter's true output, i.e. without seeing effects from amp's - input node coming through R1.
Thanks, peranders, for pointing-out the stability issue. I am going to change the schematic, to use the larger capacitances in the post-filter section.
- Tom Gootee
DJ Exprice
What we need now is a FULL schematic ;)
Something we can all go by.
I wanna use this in the BPA300 kit; one that works perfectly with it, but we'll wait on that for now until the BPA300v3 project ITSELF is somewhat more complete. :)
gootee
I have replaced the schematic of the DC SERVO, at
http://www.fullnet.com/~tomg/dc_servo.jpg
with a corrected and expanded version, which exactly reflects the schematic on which all of my original discussion and data were based, except that the post-filter's capacitors are now approximately doubled, per my last posted message. (Opamp types are not specified. But in my simulation, I happened to use an OP275 spice model, from Analog Devices' website, for all of the opamps. I also modeled all capacitors' ESRs, mostly as 0.03 Ohms.)
Anyone who has the older version of my DC SERVO schematic should note that it was actually incorrect: Without an inverting buffer in the loop, the integrator would have to have been re-configured to be non-inverting. (I guess that means that no has bothered to try to simulate it, yet!)
In case anyone is interested, I can try to post an additional version, without an inverting buffer in the loop, as well as the files needed to run LT-Spice simulations of them.
- Tom Gootee
AndrewT
Hi Tom,
the advantage of your original schematic was the DC accurate filter, even though we don't quite understand on what topology it is based.
Your new posting has inserted an opamp into the circuit. What has happened to the DC accuracy as a result? I suspect the output opamp (U1) sends it's output offset to the amplifier.
Why don't you post two versions on your site.
1) the original requiring the inverting amplifier.
2) a version with non-inverting integrator (without any extra inverting opamps).
gootee
Hi, AndrewT.
Yes, the additional inverting opamp buffer would not be good for a practical implementation, since, at best, its' offset drift would probably compound any offset drift problem.
I used it in this version of the circuit because it made it convenient to measure the voltage at the output of the post-filter and I just happened to already have an LT-Spice circuit with the integrator set up as shown. And then I wanted to post the exact circuit I had been simulating and referring to in my previous posts.
I will go ahead and put up a version without the inverting stage, with a non-inverting main amplifier. Eventually, I'll also post the same thing but with an inverting main amplifer example. I might as well also post the LT-Spice files for them, while I'm at it, since those will be so much more utile, for many people. But it will all have to wait until later today or possibly tomorrow, since it's not quite 8:30 AM, Saturday, here, right now, and I have some Curve Tracer DIY Kit orders to try to finish and get to the Post Office by noon, and then have some other things that need some attention. Sorry about the delay.
- Tom Gootee
AndrewT
Hi Gootee,
who's putting pressure on you by specifying time scales?
You're being good to us with all this research.
I and I'm sure a few others will be gratefull no matter how long it takes.
Thanks.
gootee
Hi, AndrewT,
No worries. Apparently I was putting pressure on myself. :-)
I guess I've gotten better at that, now that I've been my own boss, for a while. I'll have to try to remember that my employee only works about 16 hours a day, and will try to put absolutely no pressure on him, ALL the rest of the time. :-)
I do like doing the research, and "trying" to do design engineering. And it's somehow gratifying to share it, when I can (Must be a "character flaw". :-).
But I also get a benefit from that: I get the "peer review" process' results, which help me to improve my processes of research, analysis, and design, et al. i.e. I get critiques, and ideas, and knowledge, in return, also, which are sometimes very, very valuable (not to mention a bit of socializing, too). It's good situation, all things considered.
I'll try to let some air out of that "gas bag" employee, so he won't have so much pressure. :-)
Thanks.
- Tom
gootee
I have made the LTspice schematic for the DC SERVO, in a version that has only a non-inverting integrator and a "DC-Accurate" third-order post-filter.
I went ahead and just added it to the new webpage I have for the LTspice stuff that I come up with and decide to share.
It's at:
http://www.fullnet.com/~tomg/gooteesp.htm ,
right after the transformer-measuring/modeling section.
I hope I didn't "go overboard". (This was BEFORE I realized I was putting too much pressure on the employee who I forced to do this for me. :-) But, I like to include certain parasitics in my Spice models, now. And I think that it is especially-important for everyone to learn the best ways to run ground returns, which I am still always trying to learn more about, and "get my head around", better. And I think it would be helpful for people to realize that Spice can GIVE them most of the answers, about that stuff, without the amount of work they might be imagining, if they just set it up in their models. Yes, I'm talking about "The Dreaded PCB Trace and Wire Parasitics". Well, anyway, I set up this LTspice DC SERVO schematic to also be an example of one easy way to start to look at those effects. Or not. It works either way. Most of the relevant setup is separate from the actual schematic. That helps the schematic, for those who are only interested in that. But it also makes a nice base for trace/wire parasitics "beginners", because it should be easy to copy and paste it mostly all at once, to their own LTspice schematics.
Cheers! It's Saturday night! I'm outta here!
- Tom Gootee
consort_ee_um
As an aside another way of paralleling LM3886's here:
http://www.edn.com/contents/images/330071.pdf
Has anyone tried this technique?
I have not seen it mentioned on this forum, or have I not been paying attention!
gootee
Hi, consort_ee_um,
Thanks for pointing that out!
Yes, that's interesting. I didn't look at it in detail. But each amplifier "cell" looks, to me, like a Howland-topology current source, making a voltage-controlled current source (i.e. a transconductance amplifier).
There actually WAS a thread with a similar configuration (if I read it correctly), in the Chipamps forum, in January 2007, which is at:
http://www.diyaudio.com/forums/show...&threadid=94585
I was one of the few who responded. But the original poster never replied to anyone's questions, and the thread then died.
I still use a similar topology to implement a medium-low power amplfier (15V max/150 mA max) for my Curve Tracer's base/gate drive (see http://www.fullnet.com/~tomg/gooteect.htm ), so that the staircase waveform is user-switchable between calibrated voltage-controlled current and voltage-controlled voltage stairsteps, which it attempts for whatever load the user happens to connect. In that particular amplifier, I have an opamp with a power amp just after it, but with the opamp's feedback loops also encompassing the power amp, using a Howland VCCS topology. In such a setup, the power amp could be anything. But I used a BD139/BD140 BJT push-pull design for the "power" amplifier portion (which I might change to a small chipamp, if it's ever redesigned again, just to save a little PCB real-estate.)
Thanks again, consort_ee_um.
- Tom Gootee
AndrewT
that EDN reference (Fig5) looks just like any other inverting topology, but with the output Rs moved inside the global feedback loop.
Does moving Rs inside the FB make this enormous difference to the phase margin?
Or is there some other difference that accounts for change?
Are all inverting topologies transconductance amps since they all have a virtual earth at the inverting input pin (just after the first input resistor)?
JonHarrison
Hi Tom,
Thanks for your efforts.
I had a look at your website and tried to download the LTSpice file for the servo but got a page not found error instead; same for the plot settings and the models. Can you help ?
Jon
BWRX
quote:
It is easier to think of it simply as a differential amplifier. The input signal (voltage difference between Vin and Gnd) gets amplified across Rs. Since Rs is fixed, you have a voltage controlled current source (as Tom mentioned three posts up).
mauropenasa's my_ref design uses an LM3886 based transconductance stage.
http://www.diyaudio.com/forums/show...&threadid=62483
gootee
quote:
Originally posted by JonHarrison
Hi Tom,
Jon
Jon,
Mea culpa. At the last minute, I uploaded the files without the .txt filename extensions. It should all be working, now.
- Tom Gootee
gootee
It's actually quite different from the normal inverting amplifier topology. Notice that it has both positive and negative feedback loops. Rs is basically a current-sensing resistor. You can google "Howland Source", or "Howland current pump" (maybe try http://groups.google.com, first). They're also described in "The Art of Electronics", by Horowitz and Hill. Best results, and best stability (since they tend to be unstable because of the positive feedback loop) are obtained when the four feedback resistors are very carefully matched.
I'm not sure I have answers to your questions. In one sense, any resistor in series with voltage amplifier output could be called a voltage-controlled current source. But the Howland topology tends to create a very linear I vs V response, with the current vs voltage response staying quite linear even with load-impedance variations (probably mostly due to the current-sensing resistor and its feedback).
- Tom Gootee
Page generated in 0.14890909194946 seconds with 17 queries,
spending 0.00856614 doing MySQL queries and 0.14034295 doing PHP things.
