diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
FS: Scan Speak 25W/5565A00 4-Ohm 250mm (10") subwoofer - Click HERE for Original Thread
omarmipi
I have a used Scan Speak 25W/5565A00 4-Ohm 10" subwoofer for sale. It is in perfect working condition and good physical condition. The 25W/5565A00 can be crossed as high as 600 Hz. Here are some additional SPECS.
Technical Data:
Impedance - 4 Ohm
Fs - 19 Hz
Sensitivity - 89dB (1W/1M)
Xmax - 14mm (linear, p-p)
Max. coil travel - 26mm
FR - 19-600 Hz
Le - 0.3 mH
Sd - 330cm2
BL - 10.9 Tm
Vas - 88 L
Qms - 3.01
Qes - 0.61
Qts - 0.51
Outside Diameter: 255mm (10")
Cutout Diameter: 228mm (8.98")
Mounting Depth: 86mm (3.38")
$85 shipped fees included
_________________________________________________________________
omarmipi
Someone has provided me with the correct specs:
Impedance - 4 Ohm
Fs - 23 Hz
Xmax - 16mm (linear, p-p)
FR - 19-600 Hz
Le - 0.3 mH
Sd - 333cm2
Vas - 180 L
Qms - 2.0
Qes - 0.51
Qts - 0.41
Cutout Diameter: 228mm (9")
Mounting Depth: 87mm (3.42")
omarmipi
$80 Shipped And I will ship international at cost.
Page generated in 0.020083904266357 seconds with 17 queries,
spending 0.00799274 doing MySQL queries and 0.01209116 doing PHP things.
