diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
tonearm headshells - Click HERE for Original Thread
sq225917
guys i'mgoing to build a new tonearm i have some delicious 14mm spiral wound .5mm wall carbon tube to make the arm out of.
the question is are there any great headshell designs floating round. i kinda like the clearaudio one with the easy angle adjustment.
does anyone have a good close up image that i could base a CAD model on?
shallbehealed
vinyl engine: see library: clearaudio: gallery
Does that help at all?
sq225917
wrong headshell. but thanks.
sreten
Simple, very adjustable design, (effective length and azimuth).
The other side does not have a slot, simply the bolt for cartridge.
Though this is round, you could make an oblong version.
:)/sreten.
sq225917
Sreten, good call i hadn't thought of the SY headshell, beautifully simply.
shallbehealed
I've never seen that headshell, but it's giving me goosebumps. Will I actually go forth with my diy? Let's hope so.
Nanook
I believe clearaudio has a similar design
EC8010
Hmmm. I'd point out that using a headlump of that design on a 14mm diameter tube is going to:
Be heavy (just where you don't want mass).
Possibly crush the tube.
When I was tinkering with carbon fibre tubes, I used a bit of T section aluminium extrusion and machined one end to a circle to be glued inside the tube, then used the flat protruding along the axis of the tube as the headshell.
Nanook
if your comments regarding the weight of the headshell were directed at the type I posted...it can be made out of acrylic, or wood, or some nice unobtainium (er titanium, etc).
Personally I like the idea of acrylic (have a look at the attached immage). The volume required would need to be calculated, then the density to check the total mass if an issue. I like wood as well. It could easily be shaped, starting with a suitably sized dowel.
Having said that, I absolutely love the tonearms that you have posted (EC8010)
sq225917 just because 14mm carbon fibre is available, other stuff is too ( from a local archery range perhaps, cheapest carbon fibre tubes on the planet smilie(':) ). I have a couple of other headshell types that I could get pix of too.
oops , you need to know the arm length, mounting position, etc to do an angle offset for the headshell, unless easy to adjust types like the clearaudio type I posted, or single bolt mounted or pivotable types.
EC8010
No, I was commenting on the headlumps shown in sreten's posts; quite a nice solution for smaller diameter thicker wall tubes, but not so good for your proposed tube.
Looking at your Perspex combined clamp and fingerlift, you've solved the problem of the ringing fingerlift, but you can't clamp the cartridge very well without it and the Perspex bending. I tried a similar solution (using machined aluminium) and it was easy to align, but tended to pull the plastic housing away from the Shure M95ED cartridge.
Nanook
EC8010 , I have never had that problem. Just tighten until a bend starts, the tension will hold the cartridge. Or glue some "grip tape" to the bottom of the headshell.
I've used wood dowels and Aluminum to good effect. Best if you can give the cartridge body something flat to grab hold of, and be supported.
My fabrication techniques and skills are of the "kitchen table" variety. I have no lathe or power tools, just some files, and sandpaper. The headshells I make are intended to be inserted into the tube, to provide internal support.
If I ever get rich, I'll buy a bunch of stuff and start machining for myself. Someplace I saw a penny being used as a headshell.
YNWOAN
Hi Simon,
As you know I am also tinkering with tonearm thoughts. I favour the solution posted by 'Nanook' (the Schroeder method) for a number of reasons. I also intend to use a Carbon Fibre arm wand.
tubenut
A bit off topic but.....
Just slid these two O rings on to the lift of one of my decks.... AMAZING, never thought it resonated that much especially as it is a cast part of the arm...
sq225917
i like the easy azumith adjust of the SY headshell, and i have no worries about it damaging the carbon tube, accurate machining would ensure that is almost impossible, and i may be tempted to internally sleeve the carbon tube with a small diameter tube anyway.
for a finger lift i quite like the idea of having it come straight out of the end of the tonearm tube, like a mini version of the townshend damping paddle.
Ynoan we'll have to bump heads when i get back.
YNWOAN
Strangely (or possibly not) I have had similiar finger lift thoughts to yourself.
I agree that careful machining will militate against any damage to the Carbon Fibre tube if you choose to use the SY design. However, I'm sure you realise that set up will be a major pain in the bum with this design; way too many parameters are adjusted at once for my taste. I believe Azimuth can best be altered in other ways.
Nanook
is very easy. It could be adopted for any type of arm required.
What does "SY" arm stand for, am I missing something?
As far as the resonance of the finger lift, it has been well known for some time that removing the finger lift on Rega style arms creates an improvement.
EC8010
SY = Simon Yorke.
I use heatshrink on my finger lift to damp the ringing.
Nanook
should have guessed Simon York.
Ok, I believe Sumiko used tio sell an "analog survival kit" that included heat shrink for the whole tonearm, some goop (silicon) for additional dampening, and a couple of other items. I know some who used latex "theatre" face paint on their tonearms to good effect.
on my arm azimuth is easy to adjust. only thing I don't worry about is antiskate, but I think the longer the arm, the less likely it needs to be compensated for.
sq225917
Ynwoan.
to be honest i have two designs in mind, one largely uni pivot,so no need for azumith on the headshell for that one and also a widely spaced pivoted design.
though i'll hold off both until LesW shows his new baby.
YNWOAN
I've seen Les W's arm and have discussed both its concept and specific construction in depth with him.
sq225917
do you think he has something practical to 'home build' at sufficient quality?
YNWOAN
It all depends on what level of home DIY you are thinking. Some pretty accurate machining is required, access to a lathe would be essential at some point.
sq225917
yeh thats no issue by diy i mean i'd do the flat drawings hand them to my mate tom who's a solidworks engineer and then hand off the cad files to a small service precision cad company in sheffield.
i'd do an analogue machined dry run first as POC.
Page generated in 0.046488046646118 seconds with 17 queries,
spending 0.00776720 doing MySQL queries and 0.03872085 doing PHP things.
