| Godzilla |
I think they look nice.
Is the base a cutting board?
How does it all sound?
Godzilla |
| castlesteve |
Yes the base is a wooden cutting board from Wallmart. $2.99 apiece. I`m very suprised by the sound. These Aura 3" drivers have a really nice midrange with astonishing bass when compared to other 3"ers. I put these together as a lark to see what i could build for less than $100. I`d have to say that in a smallish room these do really well. Try a pair and see. They`re only $20 each.
Steve. |
| zayne742 |
| That is clever. Good eye! My wife hates going shopping with me for that reason, always looking at things and coming up with ideas. Lately I have been working on custom tap handles, and it is driving her nuts. |
| castlesteve |
Forgot to note that i`m hosting an audio meet at my place in Sterling Va. [ just outside Washington D.C] this weekend on June 10th. Email or post if interested. Fullrange speakers, tubes,coaxials etc. will be there.
Steve. |
| ped |
| Do you have the time to post some contruction details? |
| cuibono |
Steve - I just saw your audio meet notice - I missed it! How did it go - and when are you going to have another... please, email me, peglegpatrick (at) gmail (dot) com
Thanks! |
| gychang |
was the cabinet custom built?, dimensions?
thanks,
gychang |
| castlesteve |
Cabinets are pvc composite fenceposts from Lowes with caps glued on with liquid nails and sound deadening foam. Posts are 41" high with the drivers at 7" from the top. I stuffed above the driver with polyfill and used open cell foam behind the drivers. Ports are 8.5" up from the bottom with a diameter of 1.5" and a length of 2.5". I used wooden cutting boards from Wallmart [$2.99] for the bases.
Suprisingly good sound. I`m going to add a pair of Dayton nd20 button tweeters this weekend as the highs are a little rolled off.
Let me know what you think if you try them, Steve. |
| gychang |
| quote: | Originally posted by castlesteve
sounds interesting, since the ready-made cabinets are at Lowes.
gychang |
| Mike514ml |
Very Nice! A Lowes just opened here a couple of weeks ago, and I saw those and was thinking much the same thing. Our store had both PVC and some other thicker (and more expensive) non-plastic looking material.
I was actually looking for something 5 feet or longer to make zigmahornets. Home Depot and Menards both have some longer stuff in both 4 inch and 5 inch square. I haven't had a chance to compare thickness. I suspect the thicker and more rigid, the better sound.
Mike. |
| gychang |
| quote: | Originally posted by Mike514ml
Mike. |
can anyone run some numbers to see if these has proper cabinet size for the 3" TB here? http://www.partsexpress.com/pe/show...tnumber=264-809
or is this a "blind" trial. (just received 4 drivers...)
gychang |
| ped |
| quote: | Originally posted by castlesteve:
Cabinets are pvc composite fenceposts from Lowes... |
The posts I found at Lowes appear to be ~1/4" thick mdf with a pvc veneer, sound like the same thing? | quote: | | I`m going to add a pair of Dayton nd20 button tweeters this weekend as the highs are a little rolled off. |
How did this work out? |
| castlesteve |
Those are the right ones. I`ve not installed the tweeters yet as i`ve been working 7 days a week for a while now. I may have time maybe this week. I need to find my l pads . I`ll let you know how it goes.
BTW i have the house to myself next week so if anyone fancies getting together for an informal listen then let me know.
Steve. |
