diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Chip Amps
"photo" Caps & audio circuits ? - Click HERE for Original Thread
seventenths
Hi all,
While working on a GC and digging thru my rapidly growing parts, bin I found a couple of caps that are labeled "photo". These are 120mfd @ 330V.
Are these useful in audio circuits?
TIA
7/10
Conrad Hoffman
Photoflash caps are designed for high discharge rates, and I've seen admonishments not to use them for regular cap service. I don't know why not, as they seem to perform the same as a conventional cap of the same value and voltage. Anybody know of a reason to avoid them?
FastEddy
An example: http://www.capacitorindustries.com/web/CD17S.htm ... note that these "photo flash" types are special purpose electrolytic capacitors and may be of only slight value for DIY audio ... but experimentation may be in order. :smash:
seventenths
Conrad & F-Eddy,
Thanks for the replies...
In an effort to keep moving forward, I've left a terminal strip in the PSU section to facilitate easy CAP experimentation. I will
:smash: er-uhhhh ...test them
Onward,
7/10
Poindexter
Seven, what I've heard is that in normal service photoflash caps are charged all the way up, then completely discharged; this once a minute or so, episodically. They are designed and constructed uniquely for this odd sort of service. Put in a power supply, where they are charged most of the way up and then partially discharged and recharged sixty times a second, their service life will be very short.
If you're looking for very good, very economical electrolytic caps, have a look at Panasonic ED, TSHA, TSHB at Digi-Key. I have found nothing better, and I have A-B'd them with the heavy hitters.
Aloha
Poinz
seventenths
Mahalo P-Dexter,
Seeing your location makes me think I should fly out for a personal A-B test :D
I'll follow your advice on my next order... I have a handful of chips and a Big trafo, but still need to decide on a project. Hmmmmmm
Aloha
7/10
juergenk
hm, I find the values to small to be useful in a chipamp design
seventenths
... mine are; 120mfd 350v.
Maybe I'll make a flash;)
7/10
juergenk
yes, with 120uF/350V you can't do much exept flashes
Poindexter
Juergen,
How big are you guys using? The original schems I've seen are calling for about 1KuF as the last tank, which looks pretty small to me. 18v into an 8 ohm load is 3 amps, which is going to drain a thousand mic cap pretty quickly.
Aloha,
Poinz
juergenk
I'm currently using 1000u at the amplifier board and 10000u as charging capacitor after the rectifier
regards
Juergen
lineup
quote:
regards
Juergen
might do for you
a bit too much for a simple chip amp
in my book
of course for heavy metal music :rolleyes: we may need 20mF!!!
PS. It is NOT anything bad with high voltage rating for caps
In fact, it is good when a cap can take 200-1000 Volts
- a sign of quality. This is true for example for Polypropylene, 2.2 -10uF = input capacitors.
But for electrolytics, power Supply Caps, higher voltage means BIGGER & More Expensive.
So a waste of space and your money.
If a power Supply Cap is rated 10-20 volt above the V+ it is most cases good enough.
For a +/- 40 VDC rectifier bridge (4 diodes) supply
we can use for example 4.700uF/ 50VDC or 4.700uF 63VDC.
Regards lineup :)
Zen Mod
I remember ads from old periodics where Croft mentioned using photo elcos in his best models of preamps;
I have no intention to say that photo caps are better or worse than some "audio" grade ones.......but I really can't imagine worst scenario for one cap use than heavy discharging.......... charging and discharging it 100 or 120 times/sec in ordinary PSU must be piece of cake .........or easy task for them.......
Page generated in 0.040569067001343 seconds with 17 queries,
spending 0.00914621 doing MySQL queries and 0.03142285 doing PHP things.
