diyAudio.com diyAudio Forums Archive > Top > Source > Analogue
Phase control in 4th order butterworth MFB LPF - Click HERE for Original Thread
xitronics
I intend to design a 4th order Butterworth MFB low pass filter with 20khz cutoff.
I want to include a pot for varying the phase response for the cut-off frequency marginally (+- 15deg). Which passive component should I keep variable so as to have minimal impact on the gain & cutoff frequency..?
I have posted the schematic for direct reference.
___________
Xitronics.
jcx
in a minimum phase system amplitude and phase are codeterminant - specify one and the other is completely determined
So you can't change phase and have Butterworth response by changing any component of the filter
you can add a series all-pass circuit that is non-minmum phase and can adjust the phase shift without changing the amplitude response
Page generated in 0.016002893447876 seconds with 16 queries,
spending 0.00745273 doing MySQL queries and 0.00855017 doing PHP things.
Please support our sponsor.
