diyAudio.com diyAudio Forums Archive > Top > The Moving Image > Lighting and OHP
the best bulbs to use - Click HERE for Original Thread
makaveli956
MH 250 OR 400 watt color temp 14,000k i have tried several bulbs and these are the best you can get them at www.solarmax.com.hk
MotoMan_Yz400
I'm not sure if I'm right or not, but i would figure for a video OHP one would wont light from the smallest source point possible, to reduce blur and have a much even light field. What i saw on that site were standard florescent tube style bulbs. Not sure that would work, even tho at first i was thinking of the same thing :clown:
makaveli956
these bulbs works very good in diy projection my screen is 12 feet across and has a very bright picture plus these bulbs are only 20 bucks no blur and no washout
MotoMan_Yz400
So did you get them directly off that sight? What did you do for ballasts? And lets see some pics!! :clown:
makaveli956
quote:
just drop them an email my screen is 11 feet across and 9 feet high and the picture is bright and clear i was amazed at the performance of this bulb you can also purchase this bulb at https://secure.lumenlab.com/shop/product.php?id=57 but it cost way more if you get it from them but well worth it, i dont have pics until i get me a camera and will be posting shortly my ballast is a M59 muti tap
Bohanna
I am trying to find out the exact Model number and way to get one of these 14000K Lamps you mentioned But when I touch the Hyper Link I get a cannot find can you Please Post the exact part Number and if they have contact in the US that would be Nice too
Bohanna or stuffyhead1@aol.com
makaveli956
go here this is the bulb http://yhst-18925554572786.stores.yahoo.net/ll65k.html
Bohanna
Thanks. When I do my Lamp retro fit I will Look into it.
I already have an evo 1.2 . I used it for about 10 Minutes but it wasn't quite what I thought it was going to be. The single Low res screen and the Low Light output didn't cut it for me. The thing is sitting upstairs in it's Box . I was waiting until they come up with a High res screen and a Brighter Lamp but I think I am eventually going to sell it Locally to recoup some of My expense.
Many Thanks again!
Bohanna stuffyhead1@aol.com
Page generated in 0.029843091964722 seconds with 17 queries,
spending 0.00852060 doing MySQL queries and 0.02132249 doing PHP things.
Please support our sponsor.
