diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Power Supply Design
Supply for dual mono pre-amp - Click HERE for Original Thread
Tex Houston
Hello. A little help please. I'm wanting to power a dual mono preamp with two 18V connections for each side (one input stage, one output stage). There are 6 opamps per side for three line inputs.
I was hoping to utilise a spare Chipamp supply PCB and regulate after that. I have a 20VA 15VAC toroid I was hoping to use. Is this suitable? Do I need separate transformers or just seperate regulators after the supply? Do I need 4 regulated supplies or just two?
Any suggestions appreciated!
jackinnj
If money is no object -- two transformers -- and two sets of super-regulators -- you can set the output voltage to 18V from the nominal 14V by adjusting the value of the resistors to the error amplifier.
Tex Houston
Thanks for your reply. What do you mean by super regulators - I had just thought of using LM317 and LM337 to regulate to 18V from the rectified supply which I guess would be about 21V. What are the benefits of two transformers?
jackinnj
2 Transformers -- some of the real high end 'phile companies use separate transformers for each channel...and some use one transformer for the positive supply rail and another for the negative. If money is an object (as it is in my case) one decent quality transformer will suit the bill.
The Super Regulator thread is pretty enormous -- you can find it by entering both terms in the search engine and then selecting search by titles -- Peranders started it off.
In 1995 Walt Jung, Jan Didden wrote a series of articles in Audio Amateur in which they proposed a regulator design around the AD797 opamp which was extremely low noise, extremely low impedance -- A version of Jung's article was also in the trade magazine EDN and you can search under his name for a copy. Old Colony sells the regulator boards for about $24.00 -- and provides you with a copy of the original article.
I think that it's one of the most worthwhile investments you can make for a preamplifier.
Page generated in 0.019678115844727 seconds with 16 queries,
spending 0.00800014 doing MySQL queries and 0.01167798 doing PHP things.
