| batista |
Hi all DIY Friend
From pic
R5 @ 3 R2 Upper Frequency Cut-off Poor High Frequencies
Attenuation
C8 9 1
2pBR1
Upper Frequency Cut-off Smaller Bandwidth Larger Bandwidth
My spk respond frq 50khz-20khz 25w
i use my power amp tda2030
when music has bass i take down eq bass down( my spk is danger it dont like it )
All diy friend know value of c8 use for tda 2030 cut off frq upper 60hz or 80hz please tell me thank u |
| NIC1138 |
Just calculate it!...
But C5 and R5 determines the upper cut-off frequency, and not the lower...
If you used R1 = 22k and R2 = 680 ohms as the datasheet recommends, then
R5 = 3 * 680 = 2040
for an upper frequency cut-off of 20kHz,
C5 = 1 / ( 2 * pi * 20000 * 22000 ) = 362nF
To adjust the LOWER Frequency cut-off, you have to modify C1 and R3. For an R3 of 22k,
60Hz:
C1 = 1 / ( 2 * pi * 60 * R ) = 120nF
80Hz:
C1 = 1 / ( 2 * pi * 80 * R ) = 90nF
So you should take perhaps a 100nF capacitor for your amp...
The recommended value in the datasheet is 1uF, what gives
f = 1 / ( 2 * pi * 1u * 22k) = 7.23Hz |
| NIC1138 |
| Looks pretty... Is it three channels, and a couple of regulators and rectifiers!?... What chips are you using for them?... |
