diyAudio.com diyAudio Forums Archive > Top > Market Place > Trading Post
FS: 8" neoplanar midranges, audio caps, PCBs and more - Click HERE for Original Thread
pkpickard
One pair Neoplanar 8" midranges, stainless steel faceplates, $70 OBO.
12 HFA50PA60C 50A 600V HEXFREDs $5 each or $50 for the lot
http://www.digikey.com/scripts/DkSe...=670648&Site=US
3 HexFred diode bridge boards from group buy with spade connectors, $10.
12 Elna Cerafine 25V 220uF capacitors $1 each or $10 for the lot
4 Marcon (Nuva for Audio) electrolytic, screw terminal caps, 4700uF 80V $3 each or $10 for the lot
4 Nichicon CEW (black case/gold lettered) 10,000uF/50V electrolytic, tab caps $5 each or $15 for the lot
2 Nichicon "Super Through" KG 15,000uF/63V electrolytic, tab terminal caps $15 each
2 Chipamp LM3875 PCBs, one with the single power supply, one with dual mono power supplies. 4 1500uF 50V Panasonic caps included. $20 for the whole lot.
Linkwitz Lab MT1 PCB $30
Linkwitz Lab WM1 PCB $20
Some things from Per-Anders Sjostrum http://sjostromaudio.com/_unsql/forsale/index.html
3 SST-01 Soft Start boards $10 each or $25 for all three
6 Elesta relays (as recommended for the SST-01 boards) $8 each or $40 for all 6
1 fully populated and functional QSXPS (http://sjostromaudio.com/_unsql/hifi/qsxpsr0/index.html) set for +/- 12V, plus a small toroidal transformer capable of power it to 100mA worth of supply. Good for active crossovers. $50.
Paypal, personal check (held 5 days), or money order accepted. E-mail pkpickard at lycos dot com with any questions. Thanks!
pkpickard
Chipamp PCBs and parts SOLD
pkpickard
QSXPS SOLD
pkpickard
HexFred diode bridge boards SOLD
azngotskills
Do you have a link to specs for the Neoplanar 8" midranges?
pkpickard
They were bought from an outfit called Aurasound NW. I actually have a response curve (although it was basically on a piece of wood, not an IEC baffle or anything.) I'll try to post the curve and pictures later today. 4 ohm, 92dB/1W, capable of very high output levels (110dB+), neodymium magnets, stainless steel faceplates, 8" tall.
Thanks for the interest - more info later.
azngotskills
Im still interested but cant find any info or pictures....please update with more details when you can. Thanks :)
pkpickard
Here is a picture I took of one of the drivers:
http://picasaweb.google.com/denise....848480032383570
I'll try to dig up the response graph tonight and post it before I head out of town - otherwise it will be Thursday before I'll be able to post it.
Page generated in 0.028873920440674 seconds with 17 queries,
spending 0.00912285 doing MySQL queries and 0.01975107 doing PHP things.
Copyright ©1999-2009 diyAudio.com
