diyAudio.com diyAudio Forums Archive > Top > Loudspeakers > Full Range
BIB with 2 tangband w4-657? - Click HERE for Original Thread
Mayday
To be used as a center speaker in a hometheatre setup.
Need help calculating dimensions.
Data on drivers:
TB W4-657
Svein_B
Two fullrange drivers is normally not a good idea for a centre speaker. It will have undesirable beaming effects.
I suggest using just one FR driver.
Svein B
larkinrulez
Svein B
http://www.fostexinternational.com/...e/107e_encl.pdf
I don't think, Fostex would recommend it, if the problems would be too big.
At least it should work ;)
Page generated in 0.027148962020874 seconds with 17 queries,
spending 0.00785112 doing MySQL queries and 0.01929784 doing PHP things.
Copyright ©1999-2009 diyAudio.com
