diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Class D
ir2110 full bridge high power - Click HERE for Original Thread
umut1001
hi everybody.i have to do my university project as soon as possible..i do not have much time..i decided to build a high power (more than 250w rms) 20-20khz full bridge amplifier..because full bridge has advantages..i have 4pieces of ir2110..do you have schematics ..i need help
umut1001
heyy ..is there anyone can help?i bought 36,3volts toroid transformer ir2110 lm311 cd4069 and cd4070..do you have any new ideas to build a better amplifier?
Workhorse
Some main components LM360, 2X IR2110, NE5532, 4 X IRFP260...+ a Filter Choke
could led you to build a simple H-Bridge Class-D....with single main supply and 2 aux supplies
Here is an Idea...just a block diagram not full circuit..
umut1001
thank you..i found and bought 5 pieces of lm360..and i made a triangle oscillator with cd4069..i comparated 30khz sinwave with 300khz triangle.and i saw pwm out.i have to do my amplifier..monday is the last day..best regards
Workhorse
quote:
Umut, post your results soon, and also check the polarity of output before implementing NFDB....It is crucial...;)
umut1001
hi.it is a bit late cuz my friend post me the photo of oscilloscope late..it is the pwm out.i comparated20khz sin with 200khz triangle..what do you think about this..and how can i put it into the ir2110?which transistor may i use?
thanks for help
Workhorse
thanks for help
Hi UMUT
I think i have already posted the diagram in previous post. Use IRFP250N Mosfet as output device.....
regards,
Kanwar
umut1001
hi.. i decided to make a self oscillating amplifier with +-47volts..i will use st irf540..why using irfp250?is irf540 not enough..and i dont know how to make a volume control..could you help?do you have any schematic about iraudamp?..thank you
Page generated in 0.027723073959351 seconds with 17 queries,
spending 0.00899243 doing MySQL queries and 0.01873064 doing PHP things.
Copyright ©1999-2009 diyAudio.com
Please support our sponsor.
