| gaetan8888 |
Hi
Is there a direct (but much better) replacement ic, with very much lower distortion, to replace the NJM4565 op amp ic (with same pinout) ?
Thank
Gaetan |
| gaetan8888 |
Hi
How about the TLE2037 op amp ?
Any one try it, how it sound ?
Thank
Gaetan |
| juergenk |
hi,
it is not a replacement
regards |
| Minion |
Any standard Bipolar Opamp thould work as a replacement Like even the NE5532 would be better (Much faster and Lower noise)...
That is if your 4565 is in the Dip8 package.....
Cheers |
| gaetan8888 |
| quote: | Originally posted by Minion
Cheers |
Hi
No, my 4565 are in SOIC package. It's the output op amp of my Ensoniq audio pci soundcard.
And I have some 5532 in Dip 8 package.
Thank
Gaetan |
| Minion |
Well the NE5532 come in SOIC also....
Cheers |
| Ryssen |
| quote: | | It's the output op amp of my Ensoniq audio pci soundcard. | Why donīt you try the real ones,Lm4562 SOIC.:cool: :) |
| gaetan8888 |
Hi
Because I want to try a much better IC ;)
Thank
Gaetan |
| Fenris |
| The LM4562 is an IC...and it doesn't get much better. |
| Ryssen |
| quote: | | Because I want to try a much better IC | Good luck!:rolleyes: |
