diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
High Quality Audio Preamp(PCB Soon). - Click HERE for Original Thread
Ayne
want to take audio signal from PC sound card..
It's gain should be flat from 30Hz To 22KHz.. Low noise..
Neeed improvement??
Thread on other WEB
Thanks.
janneman
R2 is superfluous. Divide R3, R4 by 10 for lower noise.
Divide pot by 10 for lower noise.
I think your gain is too high for sound card into power amp. What's the sound card output level?
Jan Didden
Ayne
If i divide all resistor by 10 then
VR1 = 10k
R1 = 1K
R2 = 100K
R3 = 1K
R4 = 6.2K
AND C1 should be equal to 4.7uF for flat responce down to 30 Hz. Which type of capacitor(C1 = 4.7uF) i should use for goodresult??
I am assuming Output of sound card is 200mVolts and this circuit have Gain of 7.
Thanks for reply.
peranders
Have investigated how much the output voltage is? Probably more than 200 mV.
peranders
quote:
Originally posted by janneman
R2 is superfluous.
Jan Didden
Jan, this resistor can be wise to have sometimes if you have a scratchy pot and in particular an opamp with bipolar transistor input stage. If the pot is bad and you don't get any base current you will get a quite nasty output signal. JFET inputs are less sensitive to floating inputs (in short term).
janneman
quote:
OK I see what you mean, but in my book, the only right thing is to replace the pot ;) . No scratchy pots in my hifi!
Jan Didden
janneman
quote:
VR1 = 10k
R1 = 1K
R2 = 100K
R3 = 1K
R4 = 6.2K
Thanks for reply.
R1 was ok as it was.
Yes 4.7u seems OK. a good foil cap would do. Many will advise 100$ designer caps, but that's your taste.
I would think sound card output is 1 to 2 V. Google the brand/type and look it up to be sure.
Jan Didden
danville
If the source is a soundcard, you know that it will be capacitively coupled already, so there is no need at all for C1.
I can think of about a 100 better op amps than a TL071.
The size of the resistors probably doesn't matter that much in this circuit since the input level is high. Johnson noise is probably irrelevant. I would still scale down the resistors however as recommended. If nothing else, it minimizes the effects of stray C.
If the resistors are relatively small, you can consider a BJT input op amp as an alternative. You may not need an output C either if the input offsets are reasonably low.
You don't show power supply details. Make sure you decouple the op amp properly.
Al Clark
Ayne
PCB done.
C1, C2, C3, C4, C6 are added for decouple the op amp properly.
Suggest me any thing more to improvement.
What u say input Coupling capacitor should be ommited??
Thanks.
Page generated in 0.032340049743652 seconds with 17 queries,
spending 0.00915051 doing MySQL queries and 0.02318954 doing PHP things.
Copyright ©1999-2009 diyAudio.com
