| crocodile |
Hi everybody, I'm a new member, nice to exchange experience with everybody.
Now I need your help, my sansui 5000x had problems about the sound, so I need the schematic to fix it. Please help me! |
| WALTER BURKHARD |
I have from BA 5000 Sansui Poweramp.You need ??
regards walter |
| crocodile |
| Is BA 5000 power like 5000x?OK I'll try. Please post it, thank you very much. |
| 90975838 |
try this
hifiengine.com |
| djk |
5000X is a receiver that was known for it's amp problems.
Sansui used to sell complete boards of a revised design.
I suggest you contact Sansui. |
| crocodile |
| quote: | Originally posted by djk
I suggest you contact Sansui. | Thanks for your suggestion, but I think It's disconnected by Sansui for a long time ago. How do I contact sansui? |
| crocodile |
Thanks es44 very much,I'll try
Hi Netlist, thank you, but I only need Its schematic, can you take a picture of it? |
| Netlist |
It's on his way to your mailbox.
/Hugo |
| crocodile |
Thanks Hugo very much, I received it, very clean.
Best regards,
Crocodile:) |
| Netlist |
You're welcome. :)
What's wrong with you amp?
/Hugo |
| crocodile |
When I play music, Its sound is not clear, sometime generating clapping sound at 2 speakers. It wrong 6 months ago. I'm very like sansui 5000x, the tunner is good, Its sound is nice, like tube. I conbined it with sansui speaker SP-30, the sound is soft but bass is not deep. So when my sansui 5000x is ok, I will find a larger vintage sansui speaker.
Do you have any experiences about this wrong? |
| Netlist |
For ease of faultfinding, does the clapping sound occur when you connect a source (cd-player) to the AUX input? This would rule out the tuner part.
Does the problem occur when the amp is cold or rather when its warmed up or always?
/Hugo |
| crocodile |
| quote: | Originally posted by Netlist
/Hugo |
Both.
/Hugo |
Both, but when its warmed up, the problem occur more frequent. Is capacitor too old (dry) cause this problem? |
| Netlist |
I the problem occurs at the same time in both channels on the AUX input I would suspect a power supply problem. Tighten the screws (if any) of the power supply caps, tighten the screws of the output transistors and hunt for any bad solder connection. See if the different fuses make good contact with the fuse holders.
/Hugo |
| crocodile |
Sorry, I describe not clear. Its sound is not clear at 2 speakers (I think I can fix it by replace old resistances and old capacitors and check power supply).
Sometime generating clapping sound on left channel (1 speaker) |
| Netlist |
Replacing caps is probably a good thing but I rather suspect a bad connection or even a small signal transistor.
/Hugo |
| Netlist |
I suggest you contact Sansui. | Or have a look here:
http://www.robertreznik.com/sansui/sansui.html
/Hugo |
| crocodile |
| One more time, thank you very much, Hugo. With this manual, I think I can repair it. If having any problems while repairing, I need your help:D |
| Netlist |
You are most welcome...if I can help. :)
/Hugo |
| cleidi |
I've search in internet sytes but for model 5000x there are no free download.
sorry.
X Walter Burkhard.
Can ou send me BA 5000 schematics ? ThankYou |
