| jarthel |
is it okay if I "twist" my ground wire around mains wires. The ground wire is going to the ground-loop breaker.
any comments?
thank you. |
| AndrewT |
| where is it coming from and after the ground loop breaker where does it go? |
| jarthel |
| quote: | Originally posted by AndrewT
1 end of the ground wire is connected to something like this: http://www.dse.com.au/isroot/dse/im...ucts/p4850.jpg.
The other slots are taken up by the live, neutral, AC ground and B+. Another 4 is taken up by wires to connect to a motor run cap.
After the ground loop, it goes nowhere else. |
| AndrewT |
Hi J,
you've lost me.
One end of this wire goes to a terminal block and the other end goes to a ground loop breaker and then nowhere. |
| jarthel |
Hi J,
you've lost me.
apologies for not being clear.
the terminal block has 2 holes.
1 hole has a black wire that goes to the ground loop breaker. there is nothing else connected after the ground loop breaker.
the other hole has a black wire that is connected to B+ ground. |
