| yama1000m |
I've just got hold of a Sonic Impact T amp and would like to know the best way to bypass/remove the volume control/pot completely. I want to control the volume by using my stepped potentiometer passive pre amp.
Basically, modify the T amp to be used as power amp.
Do I just remove the T amp 50k pot and replace it with some 50k resistors?
I don't want to start doing all the recommended input cap mods & etc yet as I want to live with original T amp sound first without it's volume control.
I know the easiest way is just to turn the T amp volume to max but and I want to achieve the cleanest, purest sound when using my passive pre amp. |
| Puffin |
| Some time ago I produced a wiring diagram for this mod. However when I tried to attach it, I failed. I'll see if it works this time. |
| kec |
| quote: | Originally posted by Puffin
It's upside down :) |
| MisterTwister |
| are resistors really necessary? i am using mine without resistors. |
| Puffin |
If you print the diagram off and use the devices attached to the ends of your arms, you can magically turn it the right way up.
I tried to turn it around, but I only have a free version of Adobe ! |
| Fin |
| Hey!......Now it has magically turned the right way up!!! |
| kec |
I was only teasing :) |
| yama1000m |
| Thanks for the diagram on how to modify t- amp into a power amp. After listening to my new SI t-amp using a 12 volt 5 amp switch mode mains power supply for over a week, I prefer it over my £1000 Unison Research Simply 2 single ended tube integrated amp! This £30 plastic toy amp is outstanding value for money. |
