diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
Need to know about a MOS. FET output stage ( the Baby 300B) power amp plans - Click HERE for Original Thread
gaetan8888
Hello
I would like to build this MOS. FET output stage ( it's named the Baby 300B) power amp from this web page ?
http://www.geocities.com/Tokyo/5913/ (click on the "MOS. FET output stage" )
Anyone did build it and test it for specs and on a spectrum analyser to see if it's odd or pair order distortion ?
What would you say any about it schematic ?
How good does it sound compared to a good tube amp ?
Can I use a high end OPA627 or OPA637 op-amp do boost the input sensitivity ?
Thank you
Gaetan, Canada
tomahauk
this output stage have vlotage gain less than 1, if u want to have the amplitude +-30 on output, u must use preamp with +- 30V on output
like this http://www.geocities.com/Tokyo/5913/hybrid.html
Page generated in 0.018887042999268 seconds with 17 queries,
spending 0.00861764 doing MySQL queries and 0.01026940 doing PHP things.
Copyright ©1999-2009 diyAudio.com
