diyAudio.com diyAudio Forums Archive > Top > Amplifiers > Solid State
carver m500-t schematics - Click HERE for Original Thread
morpheus82
hi guys, i've found a nice carver m500-t but it's faulty, 4 transistors are blown an i can't see the model of the transistors, does anyone has experience with it?i need at least a schematic to try to repair it...thanx a lot in advance!
morpheus82
anyone?maybe someone who knows the transistors inside the amplifier...please!:bawling:
toddyaudio
Those transistors are long obsolete, most likely NEC B705 and NEC D745. Carver had a service bulletin to replace them with 2SA1302 (also almost obsolete so use 2SA1943) and 2SC3281 (also almost obsolete so use 2SC5200). The new transistors are a different case style so you will have to get creative when mounting the new transistors. I have used these transistors in a M500 without any problems.
morpheus82
thanx a lot mate!but these are final transistors, but on the same heatsink there are also smaller transistors, and they're blown...maybe i'll post a picture asap..do you have a service manual?can you send it to my email?and do you think i have to chack other components?
morpheus82
ok, transistors found, but the name i a fabric name! namely
A1111
C2591
how can i know which replacement to use?:confused:
Page generated in 0.021783113479614 seconds with 16 queries,
spending 0.00930285 doing MySQL queries and 0.01248026 doing PHP things.
Copyright ©1999-2009 diyAudio.com
