| which is which in a headphone jack? - Click HERE for Original Thread |
| jarthel |
is the tip the left channel and the middle one the right channel?
I found something like that in a wiki but wiki entries can be made by anyone so I like to verify their contents.
thank you. |
| Sonusthree |
| quote: | Originally posted by jarthel
Yes. :smash: |
| panomaniac |
Yes again.
And the barrel is ground (common). |
| OzMikeH |
the way I remember it is:
Ring = Right = Red
As in Tip, Ring and Sleeve. |
| jarthel |
| thanks for the help |
| sorenj07 |
| while we're on this topic, does anyone have a source for stereo headphone jacks (preferably 1/4") that DON'T connect ground straight to the chassis? i'm trying to build a linestage/headphone amp and would rather not cut out a square to mount PCB to insulate it.. |
| jarthel |
| quote: | Originally posted by sorenj07
cliff components (http://www.cliffusa.com/) has them. not sure where you get them though.
http://www.cliffusa.com/datasheet/1...K%20SOCKETS.pdf |
| dnsey |
| Or Bulgin or Rendar, or any number of generic Far Eastern 'plastic block' types. Try your local music shop... |
