diyAudio.com diyAudio Forums Archive > Top > Other Stuff > Electronics and Parts
Tektronix 2213 - Where to start? - Click HERE for Original Thread
sorenj07
Hi, I just picked one of these up for a reasonable price off eBay. It turns on, and I get a dot in the middle, but I have no probes or anything. I found and downloaded the service manual, but have yet to make heads or tails of it. First off, does anyone have any recommendations for probes that I should try picking up? I don't know what else to do to make sure the thing works, I assume that fooling around with my CD player's output once I have probes should give me more of an indication...
XEAGLEKEEPER
soren
Ideally a x1/x10 probe or one of each.
Can you get a verticle trace with no probes? Select say 500ms on the sec/div and 500mv on the volts/div.Select channel 1 DC and you may have to adjust the trigger control a bit.
Dave
sorenj07
Unfortunately, this is what I got after fiddling with a few settings. Bad, I assume?
XEAGLEKEEPER
That don't look good:eek:
If you dont mind me asking ! I hope it was a real reasonable price-I take it ,it was (as is) needs work price.
Dave
sorenj07
$50 or so including shipping. I was actually anticipating having to do some work on it. Should I pop the cover and take a look? :smash:
XEAGLEKEEPER
Well it looks like a vertical sweep problem.What have you got to lose.
Dave
XEAGLEKEEPER
Be careful.I'm sure your aware of very high voltage on the CRT .
Dave
sorenj07
Yeah. There's a little cluster of Sprague .01uF 4000V caps near the wire headed to the anode of the CRT :) Unfortunately, I have absolutely no clue what to do. I'm reading this thread:
http://www.diyaudio.com/forums/show...10&pagenumber=2
but I'm not positive that his and my problems are the same.
sorenj07
Flipping the thing over, I saw a few areas with burned components. The Sharpie writing on the board confirmed my suspicions that someone else had tried to service this scope. A bunch of screws are also missing from the chassis, and some of them looked a bit chewed up. I guess he wasn't very good at repairing things...
Page generated in 0.027843952178955 seconds with 17 queries,
spending 0.00751209 doing MySQL queries and 0.02033186 doing PHP things.
Please support our sponsor.
