| v-bro |
| There new amp out with the same chip as AMP5, called AMP10. And there is a new amp with the very good sounding and very powerfull TA3020 chip from Tripath, called "Truepath". The latter uses a 4-layer double weight PCB, so the shielding is optimal.... |
| soongsc |
| I wish they would add diffential input to the design and get rid of the decoupling caps. |
| Korrah |
| I've asked Jan about that, and he's supposed to be in the midst of working on a design that uses differential inputs but I haven't heard from him for a while. |
| v-bro |
And now Truepath is available. A 2x300Watt amp with TA3020!
A lot of power from a 10x11cm PCB!!
It seems it is going to replace the AMP2 kit.
Truepath has a 4-layer PCB to keep lead inductances minimal and provide maximum shielding :cool: |
| kstagger |
| I'll be ordering the AMP10 kit sometime soon... I need a new project and a little more power than the Charlize. |
| v-bro |
| Good choice! If you still feel like more power you can get a second one and use them both in bridge mode (simple jumper connection...). |
| v-bro |
I'm building a Truepath kit at the moment.:cool:
Will post pics here soon...
It's looking very very good! I expect to finish the soldering this week, than I hope it sings!:rolleyes: |
