Ok guys.... its a bit hard to start on a cold morning
but .this toobe amp that uses an ignition coil certainly is an odditie in itself.... I wonder how it sounds? BTW: The guy that wrote up this little gem seems to dislike buying NOS toobes from now defunct American manufacturers.... Go figure....
Mark
Mark
nice article for noobs
besides that-driving anything (besides grid of next toob ) with 12AX7 is same as driving 50 mosfet gates with one 2SJ109.
go figure
go figure
Maybe he didn't want the vast throngs of people trying his project to use up the remaining stock of NOS 12ax7s? 🙂
This appears to be a part of an electronics course- there would be no point in spending £££ on a NOS 12ax7 when a current production one will work for the demonstration.
Parafeeding the 'OPT' would appear to be a good, if expensive, idea- no high voltage DC on the speaker terminals.
James
So which coil would work the best...One from a Model-T, one from a Jaguar, or one from a Mercedes?
Mark A. Gulbrandsen said:So which coil would work the best...One from a Model-T, one from a Jaguar, or one from a Mercedes?
No, with a Sovtec tube, only a Lada will provide the correct load.
Andy
I have seen discusion of the use of two low voltage transformers back to back to produce the HV on this forum. How do you calculate the amperage on the final 115v?
I've seen this idea somewhere before, but never tried it. I'm sure I have an ignition coil around here somewhere. If I were more motivated I'd measure the inductance and stepdown ratio...
Anyway, it seems to me that the coil is not really hooked up right. As drawn, the speaker voice coil (along with any interconnecting wire) is riding up and down with the plate of the tube. That's a huge common mode signal that serves no purpose and loads the tube with all of the capacitance to earth.
It makes a lot more sense (to me) to put the small section of the winding (the part that the speaker is connected across) at B+ rather than at the plate of the tube. To make the change just swap the plate and B+ connections in the drawing: connect B+ to the '+' terminal on the ignition coil and connect the plate to the center plug.
-- Dave
-- Dave
I seen it last night also and I just had to know.
Yes it makes music, not just noise. It was not great, but I have heard some A/V amps that sounded just as flat.
I wouldn't build one again but it was to easy to pass up.
Yes I had to play with the coil wiring.
Glenn_G said:I have seen discusion of the use of two low voltage transformers back to back to produce the HV on this forum. How do you calculate the amperage on the final 115v?
I assume you'll have two 240/12VAC xfmrs or similar? The output should behave in theory just like the mains supplying current to the load. The 12V windings would be handling 20 times that current. The combination is limited by the capability of the xfmrs to deal with this load.
In theory, current won't flow unless you load the second secondary (or primary just for confusion's sake
I feel that toroids may be better for this duty, and a smaller turns ratio would also be desirable.
Assuming you have two identical transformers, it would be the secondary current rating divided by the voltage ratio, for instance if you had two 120V to 12V transformers and the 12V secondaries were rated at 10A it would be 10A / (120V / 12V) = 10A / 10 = 1A.
Since there are losses in the transformers you'd get a little less than that, so leave a little safety margin.
- Tubes / Valves
- Ignition Coil Toobe Amplifier
