Using woofers for Bass Guitar Amplifier
Moderator
Joined 2002
Hi
As above.
I've seen most pro equipment has regular guitar speakers used as bass amps. Maybe larger, but essentially stiff, low Xmax 10" or 12" speakers much like the regular PA stuff.
Question: I have A couple of spare pairs of 12" woofers laying about. Not very good for Hifi, but cabinets are expensive so I was wondering if I could use the woofers for the Bassist (he doesn't have an amp, and he ruined one of mine by playing bass through it). Throw in a couple of TDA 7294 Amps, and pray to God they don't blow in the middle of a show.
Whaddya think??
Pinkmouse?
Anybody?
Hi Sangram
I see no reason why not! In fact, if it saves your hi-fi, it sounds like a very good idea🙂 .
If you have TS parameters, just work out a decent closed box size and go for it, otherwise I would go for something around 150l as a quick guess, based on portability issues rather than sound!
It might also be worth adding a couple of cheap piezo tweeters to add some sharpness to the sound, otherwise it could sound a bit muffled and boomy. The advantage of these is that no crossover is required for basic use, they can just be wired straight in.
Does your mate have a preamp, or is he just plugging straight into the cab? If the latter you may want to just knock up a little preamp with basic passive tone controls.
I am not familiar with the TDA 7294 chips, but I would be a bit wary unless it is just used at low volumes, or for domestic practice, and even with such, I suspect you will need huge heatsinks, but hey, If you have the chips lying around then go for it! Otherwise it might be better to look at something like the ESP sub amp, with the extra output devices Rod recommends for 4ohm use.
Good luck🙂
Thanks pinkmouse.
No I can't get any parameters for the drivers. 150L sounds about right, I may look at picking up a cheap compression driver for it.
I have one TDA 7294 laying about, it should give me about 40 watts into 8 ohm, should be enough for light practice duty. I'll be making a separate head with that amp (The chip is rated at 70 W/4 ohm, and I have a spare 225VA Xformer for it). That way I'll have a pair of 200 watt/4 ohm capable cabs which have enough grunt to take on a quality amp later.
Thankx.
Sangram
How things change in a few days.
Happy 2003 BTW. I'll open with a question: How much gain should a typical guitar signal have so it can reach amp-driving level? I thought about x100, but I'll wait for responses.
I spent new year's day on my gear.
Repaired a combo, whose speaker had blown at the last rig.
Finished the PSU and poweramp of the Bass amp. I see it as a small home practice unit as opposed to a big rig.
I now see it as a small head into which three guitars can plug in, including a bass, as opposed to a dedicated bass amplification system.
I see that the 7294 would not have been powerful enough to drive the 2x12 cabs.
So I built a speaker using a leftover 8" Philips woofer rated at 60 W RMS, and a horn tweeter of unknown antecedents. Extremely high pressure, so sounds very bright when playing music, but seems OK when playing a regular guitar through. Yet to try with bass.
The head is a 7294 based amp. I'm a little worried about heatsink size being on the smaller side, it's about 5" and I have no clue how much heat it can sink. I've used a CPU cooling fan to blow outside in onto the heatsink, more for insurance. I'm hoping the thermal cutout of the 7294 can save it in case of any emergencies.
It's very noisy, though, So I'm going to consider using a thermal switch for the fan, or run it off the 9V supply for the preamp instead of the 12V winding of the trafo.
The supply voltage is now at about 27V under idle 4 ohm load, since I got a new 120VA trafo for it with a 40V CT winding instead of the 50V CT 225 VA trafo earlier.
I'm still rigging up the preamp. For the moment, I'm going with an assembled microphone preamp, which takes a mixed input from three emitter followers, one for each channels. I plan TL074 based preamp in the near future, to check if the JFET in the opamp helps the tone. I need to know gain figures, though. I had planned 2 stages of x10, one for each stage and one final summing amp, that way a TL074 gets fully utilised.
I wish I had a Digicam. Actually, no. The chassis is pretty flimsy but it's only meant for in-home practice. I will rig up some cabs and a good 200W RMS amp for it. That's now a later project.
Should be rocking on Sunday's jam.
Cya
Done!
All done, it's rocking!
First run with the bass guitar is tomorrow.
Even if it doesn't go through there, I have a rocking acoustic guitar amp and cab. I've never heard such great acoustic sound plugged in, sounds like a real miced acoustic.
Weight of bass is amazing, with the picking and damped plucking. The entire amp is covered with silicon sealant to damp vibrations etc.
Three inputs, two with regular 40 dB gain and one with monster 60 dB gain for really quiet stuff.
I love this profession. Total cost of parts (excluding stuff I already had) was about $20...
Dude, the amp rocks.
I was at the first succesful practice yesterday. The bass never sounded so good. Never.
On the first attempt, I had forgotten the wire. We bought some lamp cord which caused some horrible feedback.
There are three inputs now, the bass is on one of the low inputs. I'm using the single high-gain input to mic one of my backup singers. This has freed up my guitar amp and should ensure its speaker last longer than a few sessions...
We practiced for about three hours yesterday but the amp never even got warm....
off topic...
Hi sangram,
This is off topic, but what's your band called?
Will some of those cheap (read: fake 🙄 ) 2SA1302 and 2SC3281 transistors paralleled in a well-heatsinked P3A type amp will be good for this kind of work?
I ask because I have a driver that sounds a bit like yours: it's a 1950s vintage Altec-Lansing 12", whose cone had been eaten up by insects. After getting it reconed (at SP road... urk!) it's very stiff.
Hi
Our band is called Vayu. We basically do classic rock - 60s through 80s. Well, mostly...
We just got together, three months ago in fact.
My bassist used my little cube for his bass work. Obviously, the speaker blew up. Actually it didn't but the surround (these are those full range speakers with the edge of the cone doubling up as a surround) got torn. As a result my guitar tone was sounding bad.
I guess a P3A type amp will be good. Just be careful of the voltages - the fake transistors are a little dangerous. I would suggest thermal protection or cutout, as a fan + relay + a few components is generally cheaper than a large heatsink.
I guess an amp like that would be great for guitar, though. Guitar doesn't need much power - I can barely listen to a 30 Watt guitar amp at full blast, whereas my 7294 at full blast (close up to 80 watt) on a bass guitar sounds just pleasantly loud...
Just check how high the 12" will go, though. About 6 KHz should be fine. I would also be doubtful about the ability of the coil after you've got the speaker repaired. I wouldn't actually try to put more than 30 watts into it.
Any Music Samples - from the Band
sangram said:
Hi
Nice to hear about the Band you are playing in. 😉
- What I wonder, sangram
is if you have a 😎 website 😎 - for the band?
- And if it is possible for me to get
some music sample - some file, mp3 or like that?
I would surely be interested to get a sample. 😉
If you have no website for the band yet,
Get one - I have at least 5 free Homepages (see my profile)
Kindest regards from Sweden to India
/halojoy :note: :Piano: :note: :hphones: :note: :Piano: :note:
Hi sangram..
Good to know that your rig is rocking. Congrats. You are continuing in the fine tradition of Calcutta's, and the Bengali’s, contribution to the audio engineering and music scene in India. I can think of Ashok Mukerjee (Sonodyne), Bose and Allied Acoustics in this connection. As long as guys like you are around, Calcutta will retain its label as the best rockers and audiophiles city in India. BTW do they still sell LP’s for Rs. 15 each at Free School Street? In my days I had picked up some rare Al di Meola and ELP (Pictures at an Exhibition – Double LP –only 50 bucks in 1995) stuff there.
Why don’t you consider an EL84 combination for your guitar? You can find an appropriately cheap output transformer in the Chandni area. Valves are still not a problem I think. Alternatively you can scrounge around Tent & Sound Rental shops (tentwallah's) looking for an old 6V6 Ahuja or Monarch Mono PA amp. These amps can be refurbished at a reasonable cost and some even had built in effects. These will make a great guitar amp.
Most of the older tentwallahs also used to hire out cubes with a single 15’ Hermon unit. Though rated at only around 30 watts, this was a very respected piece of gear for the day and would make a fine guitar speaker if properly re-coned today.
And while we are in it do check out http://www.standardrobotics.com These guys are in your neighborhood.
Thanks halojoy for your interest in our band. I like halomatics!!
Unfortunately our band does not yet have a website. We need a good place to put up our profile and our philosophy, and we are looking out for a host but not very high priority.
We have started very recently and are still having very little equipment, and also no original music. We have a few band videos etc. which are being digitised, and as soon as they are done we will look for a place to host them...
As for original music we do not have any compositions down yet but we are going to do some very interesting covers, like a death metal version of Beatles' Norwegian wood, and so on. We hope to graduate to compsing our own stuff soon, as soon as we find our feet while playing covers.
I am taking the liberty of adding you to our mailing list, though, so when the site is up you'll be the first to know. I will also put links to our music.
Corbato:
Thank you for your kind words. Sonodyne is now being run by Anindya, his son. Obviously the philosophy and products have changed somewhat. LPs are still selling at Rs. 15 on Dharamtala street and free School street, some very rare ones also.
On tubes, I have found RCA original 6L6 tubes at 375 bucks each, a steal if you ask me, but unfortunately no transformers, either output or power transistors. I have however been thinking of a hybrid with a tube pre using 12 AX7 (for which I believe 300 volt lines are easy to generate off a low V supply) and a solid state 100 watt section. Unfortunately my numerous excuses have got the better of the intention for now, so I am still waiting to transform that into action.
Standard robotics is the guy who supplies the sound to all the Kolkata gigs. He's unmissable...
Thanks for your interest and encouragement. It really means a lot to us.
I don't like using this board for stuff like this, but our email id is vayu@@musician.org Remove one of the @s to send a mail.
great place cal
Hi Sangram,
I doubt if Sonodyne would be able to recreate those amps from the '70s. Absolute high end audio. Remember their SCA series 180 watts RMS :bigeyes: back in early 70's !!!. Recently when I was looking at surround systems, i had a look at their 'Take 6' model which -although quite ok - just did'nt sound like a Sonodyne. They are selling some weird Bi Amp sustems.
As for that 6L6; do look around the Madan Street area. you just might be lucky with an output transformer. For push-pull operation you should be looking for an raa of aprox 8000 ohm and most EL84 transformers will be ok imho. Look for the 'Delta' brand. They were made in huge numbers. Though I must admit that my knowledge on tubes is shaky at best.
If you still need a transfomer then email me at bht5180@@hotmail.com, but then you will need to have it collected from Delhi.
All the best.
Thanks for the offer... I might just take you up on it, though. I travel pretty regularly to Delhi.
Yes I remember the old Sonodynes. Those were amazing amps by any standards, even their combination player+amplifiers were extremely high fidelity. I have not seen many of those amps in circulation in the second hand market, but plenty of Kenwood and Sansui. The Sonodynes are where they were intended to be: In homes...
We're going majorly off topic here, so here's something to close this...
I have ready access to some of those schematics, actually there is one guy in Cal who is selling kits based on those vintage Sonodynes - 50 watt RMS transistor based amps, excellent stuff compared to most local amps but in no way even close to the Sonodynes. Even after building them with 1% MFRs, tantalums etc. they are sonically different.
There are few points of view, chiefly that the transistors are no longer available so they are being substituted with equivalents. This is the chief reason, also the PCB does not have the exact same layout, and cap values etc have been somewhat changed. Power supplies have changed over the years, and the overall design is more 'efficient' than the 70s builds.
I have tried to build about ten of these amplifiers, and whereas I can say they are excellent amplifiers they do not hold a candle to the real thing. However for one who is bored with the 3055 based '60 watt' amplifiers this is a major step up.
And I am not saying they are different from the point of view of copyright issues only (these of course exist and no one will claim copying a design from Sonodyne, or anyone else for that matter.
