Hi!
I've tried some i/v converter to my (dual TDA1541A) dac, but, this is the best. Look at the schematic:
Very-very good dinamic smooth sound. The high and middle frequencies are very good too.
Adjusing:
adjust T1's emitter resistor value. Set DC 0V to the TDA1541A output
Comment:
- the output condensator is paper in oil type
(the input resistor is for protecting the DAC output when the i/v converter's T1 dies.)
This is inverting he input, and this is good! We need to invert it to the correct phase! So every TDA1541A's converter need to do this.
Sorry for my bad english...
Is there somebody wants to try this?
Istvan
Adjusing:
Comment:
Istvan
istipisti said:Hi!
Adjusing:
Comment:
Istvan
Hi
Nice circuit, reminds me of the circuits I built for MC cartridges.
I'd suggest to remove the input resistor, as you want a low input impedance, the resistor degrades performance.
You can protect the DAC by adding antiparallel diodes (I use 1A Schotkky types), so the DAC never sees mre than say +/- 0.3V at its' output. This shouldn't be a problem.
You may want to replace R6 by a current source and add some emitter resistance to T2, this improves linearity.
best
Hi Guido!
Thank You. The Schotkys are good solution for the protection! 🙂 The bottom resistor was current source in my first simulation, but... I believe in the "minimal concept". Maybe it is better.
I think my circuit sounding similar to the John Linsley Hood Class A.
But, we can put in some resistors and transistors and...
I think, my version is better. 🙂
istipisti said:Hi Guido!
Hi Istipisti,
Well, I like minimal too, so why adding 2 transistors ?
I myself have designed a tube based IV converter with less than 1 ohm input impedance to mate with PCM1704.
best
Guido Tent said:
Hi Istipisti,
best
Hi Guido,
All tube or hybrid cascode?
Cheers
Terry
Terry Demol said:
Hi Guido,
Cheers
Terry
Hi Terry,
There's many transistors around the tube, mainly for biasing
best
Tube I/V
Hello Guid
Does the Tube achieve low input resistance by its self or is there a transistor between the DAC and the tube.
Do you have feed back around the tube?.
Arthur
Hello Guid
Arthur
Re: Tube I/V
Hi Arthur,
It is a mixed bag of everything, tubes intrinsically do not achieve 1 ohm input resistance.
best
PHEONIX said:Hello Guid
Arthur
Hi Arthur,
best
Re: Re: Tube I/V
Hello Guido
Have you ever been tempted to build an all valve I / V stage which achieves low input resistance, and it would also be nice if it was direct coupled.
Reagards
Arthur
Guido Tent said:
Hi Arthur,
best
Hello Guido
Reagards
Arthur
Re: Re: Re: Tube I/V
Hi
All valve is possible, but I use transistors where they come in handy, e.g. biasing tubes. To me, valves are not a goal as such.
Mine is DC coupled. It has antiparallel Schottky diodes at the input to protect the DAC chip output........
best
PHEONIX said:
Hello Guido
Reagards
Arthur
Hi
best
Guido Tent said:
Hi Terry,
best
Hi Guido,
Yes, I understand 🙂 This is a very good approach to I-V.
I think generally it is cleaner (more linear) but maybe a little less
euphonic than the usual dac into small value R into tube grid.
We have been using various iterations of the theme for about 5
or 6 years now.
If you can DC couple it then this is maybe the ultimate I-V I think.
Cheers
Terry
Re: Re: Re: Re: Tube I/V
Guido,
Have you managed to do it (DC coupled) without a servo?
If so that is very impressive.
Terry
Guido Tent said:
Hi
best
Guido,
Terry
You put in antiparalell diodes. Doesn't it degrades the sound quality?
best
István
Normally there won't be running any current through them. 🙂
Re: Re: Re: Re: Re: Tube I/V
Hi Terry,
Yes, a servo at that point is hard to make transparent for sound. Downside is that some readjustment is needed once tubes are changed, or when they alter very much.
best
Terry Demol said:
Guido,
Terry
Hi Terry,
best
Yes, that is the answer, as long as the input impedance is low, the voltage swing is low as well (mV's)
best
Hello Guido
Why use a valve at all if it is not a goal as such. You can build the I/V stage totally with silicon Direct Coupled and no valve issues.
Arthur
Guido Tent said:
Hi
best
Hello Guido
Arthur
Hi Arthur,
I know, but I like a valve at that specific place
best
PHEONIX said:
Hello Guido
Arthur
Hi Arthur,
best
Re: Re: Re: Re: Re: Re: Tube I/V
Hello Guido
So you like the sound of valves and thats why you use it. I too like valves.
Arthur
Guido Tent said:
Hi Arthur,
best
Hello Guido
Arthur
Re: Re: Re: Re: Re: Re: Re: Tube I/V
I don't like typical valve sound, too euphonic in my observation. If applied correctly, valves can sound very transparent, without adding "sound".
cheers
PHEONIX said:
Hello Guido
Arthur
cheers
- Digital Source
- Very good i/v converter
