C
CryingDragon
Did you all know that using wire with red insulation to carry positive and black to carry negative will help in keeping the polarity separate thus reducing ripple?
This is nothing new.CryingDragon said:Did you all know that using wire with red insulation to carry positive and black to carry negative will help in keeping the polarity separate thus reducing ripple?![]()
In fact these colors have been used
for ages to improve the electrical qualities of circuits.
It is important to polish the insulation
every now and then,
to keep the currents fresh and clean. 😎
C
CryingDragon
And green is best for ground, It helps immensely in reducing ground loops because, as we all know then color green is very straight on the molecular level thus making the loops straight and thus eliminating them 😀
NEED A NUTCRACKER??
We the colourblind use unbleeched coton insulation for best sound.
In that way the deaf can hear what the blind have to say.
Ciao.😉
Ciao.😉
Now I'm really confused. Electrons are yellow, why haven't the cables yellow insulation? My research shows that electrons runs faster in yellow cables. The noise is also reduced.
As you all know, there are red, green and blue quarks and quarks
make up the protons and neutrons. Hence you should avoid
using any of these colours for insulation, since it will confuse the
electrons, which won't be able to tell the insulation from the
atoms they jump between, making them run into the insulation
and get stuck there every now and when. 🙂
I installed a lightbulb inside my amplifier and speaker cabinet so the electrons can see where they are going. The result is a much brighter sound 😀
NUTCRACKER - ME??
The sound you get, is somewhat less plastic and more soft.
For REAL high end, with a smooth, warm and rich upper rolloff,
there is only one thing:
HAND-WOVEN NATURE SILK
Cotton can do for most of us.fdegrove said:Hi,
We the colourblind use unbleeched cotton insulation for best sound.
Ciao.😉
The red ones ALWAYS go faster. Use red for everything... The sound will be faster and so will be the electricity from the mains.. 🙂 Faster power means better bass!!!!!!! I tink..
SILKY SMOOTH.
Where do you buy your caterpillars?😀
Ciao,😉
Ciao,😉
CryingDragon said:And green is best for ground, It helps immensely in reducing ground loops because, as we all know then color green is very straight on the molecular level thus making the loops straight and thus eliminating them 😀
Actually for the ground you must use a wire that has two colours which need to be complimentary to the plus and minus wire colours otherwise you will not be optimal for the return currents and imbalance will occur. Common mistake.
/UrSv
PS. Having a light in the enclosure can be very good but I once took a 100 W bulb and blinded my signal so that it actually never came out. Be careful and use just the right light intensity so that it is comfortable but not too bright for the electrons.
NO, NO, NO, you are just confusing them with all the different frequencies of light!
What you need is 3 tuneable lasers with light pipes surrounding each wire. This will allow you to tailor the frequency response of each laser to the exitation frequency of the colour of the sheath, causing the electrons in the sheath to bounce around madly. This will stop the needed electrons in the cable from getting into the insulation, and keep them on the right path.
However, this now means I have to use blue wire for my negative rails, as when I used black, the military surplus UV laser I used took out my amp, walls, and fence outside, as well as half the block!😀 😀
Re: NUTCRACKER - ME??
No, no, silk is over-rated. Cotton is at least as good, but make
sure you get ecological cotton which is non-toxic, or the electrons
will show sub-optimal performance.
Coloured Sonics.....
Dyes used to colour insulation affect the dielectric properties.
Different dielectric properties affect sonics.
Avoid dyes containing Cadmium.
Chromium dioxide pigment sounds good.
Eric.
Eric.
FOOLING AROUND.
Think none of them were seroius about this anyways.
Little do they know that chemicals do affect sonics as do plastic polymers in general.
They probably never heard about fluorines,they don't know about field effects,they are in general ignorant about anything.
But I forgive them,🙄
Just because we were having some fun doesn't require personal insults, Frank, I think an apology is in order...
But I forgive them......Why ?.
and "None so blind as those that will not see" and "None so deaf as those who will not listen"
Idiots and stupidity
Eric.
Eric.
- Design & Build
- Parts
- Follow up to cap sleeve thread,Wire color makes a diffrence!!
